Parting out audi 90 1990 quattro 20v tornado red
Old 02-17-2015, 01:27 PM
edges's Avatar
Default Parting out audi 90 1990 quattro 20v tornado red
Hello everybody!
Like the topic says, parting out an Audi 90 1990 quattro 20v tornado red
Car has been completely parted out and I kept all the parts, even small rare parts.
if you are not seeing some parts on the list, I probably am just forgetting something...so just ask
List of parts that I have:
Tires- TSW Hochenaeims/Bridgestones Potenza RE-01 R (225.50.16)(16x9) 5 on 112 tires with wheels $800.00
Intercooler UR S 4 FMIC 2 MC-1 1C'S $50.00
Window Regulators UR S 4 with Doors and Sunroof $100.00
7A Head Complete (No Cams) $150.00
S4 Pedal Set $30.00
Steering Coloumn Tilt TELE $30.00
Short Block A4 V6 Short Block with Heads $150.00
90 CQ 5 Speed Exc. +Drive Line $150.00
Distributors 7A + MC-1 $100.00
Crank Pulleys 7A + MC-1 (182093) $50.00
Doors C-4 doors +Rear Deck lid $50.00
Transmission 01A with mounts $150 each (we have 2)
Front Subframe with buhings $60.00
Front Control Arms $25.00 each
Left Front Ball Joint $10.00
left Front Axle $40.00
Left Front Knucle with 4 lug hub complete $35.00
Left Front Strut complete $30.00
Front Calipers G60, w/caliper carrier$100.00
Power Steering Pump $100.00
ABS Sensors $5.00 each
ABS Pump $80.00
Windshield Wiper Motor $50.00
Rack and Pinion $100.00
Break Bomb $50.00
PS hoses $30.00 high pressure 20$ low pressure
Steering Coloumn $20.00
Master Cylinder $40.00
E-Break Cables $15.00 each
Gear Shift Linkage $20.00
Pedal Set complete $25.00
Inner-Outter Tierod Left Front $15.00
Alternator $50.00
B3 Headlights with clear Turn signals $100.00
Doors $50.00 each
Window regulators $30.00 each
Radiator Fan $40.00
"Oh ****" Handles w/ Lights $20.00 for all 4
Drive Line $50.00
7A Loom w/ complete harness + fusebox no one wire was cut $220.00
Rear Bumper with brackets $100.00
Tail Lights $120.00 for All 4
Wheels (4 sets) $400.00 ($100 each)
speedliners painted black without hub caps 100$
speedliners good condtion with hub caps 140$
B4 audi 90 wheels with hub caps 120$
B3 audi 90 quattro wheels with hub caps 120$
Stock Radio i do have a code for it $60.00
Gauge Cluster $40.00
Whole Heater Assembly (Rebuilt) making it hot inside $120.00
Trunk Door $60.00
Rear Differential with diff lock and mounts $150.00
Rear Subframe with bushings $60.00
Rear Control Arms $20.00 each
Rear Knuckles with 4 lug hubs $25.00 each
Rear Swaybar w/ Endlinks $35.00
Rear Axles $30.00 each
Rear Tierods $125.00 both
Rear Calpiers $25.00 each
Gas Tank nice and clean $50.00
Front Swaybar with 1 end link $40.00
Fuel Pump with filter $25.00
ECU 2 Port Connector $75.00
Windshield Wiper hands $5.00 each
Exterior Lower Door Side Trim (Rubber) $70.00
throtle cable $20.00
inside door handles $20.00 for set of 4
Windshield Fluid Resevour $25.00
door seals $25.00 for all 4
door wire boot $15.00 for all 4
hood seal $5.00
vaccume resevour $10.00
Seatbelts w/ recievers rear and front $5.00 each
hood shock $5.00
front breaks (rotors + pads) almost brand new 4 lug $40.00
plastic hood cowel $10.00
Horn $5.00
Control Modules : -cruise control air pump $25.00
- air pump door lock $30.00
Parts that gone:
7A engine complete
All interior
Front fenders
Rear struts
Heater core support
Hood
Front bumper
Fog lights
Coolant and ps reservoirs
Both radiators
Let me know what u need better deal for those who buy in bulk. and of course cash talks
Pm or text 425 3sixsix9303
Parts located at Seattle WA
Thanks
edgesappy
Old 02-26-2015, 08:43 AM
4ringsinutah's Avatar
Default drivers side and rear passenger door weather stripping
Would you happen to have the drivers side and rear pas. weatherstripping that goes around the body side of the door frame? also do you know if the 93 year 90 body//doors were the same as the 90 year of the car?
Old 02-26-2015, 10:52 PM
egp320i's Avatar
1990 90 were B3 based body style, 1993 was the B4.
A few but not many body parts carried over.
I'd have to cross ref to be absolute.
evolveo
12-10-2016 08:00 PM
edges
Inline-5 Discussion
09-18-2015 09:22 PM
edges
03-08-2015 04:58 AM
edges
1.8T Discussion
02-20-2015 11:43 AM
Cory
Misc. Models Discussion
12-15-1998 07:54 PM
Quick Reply: Parting out audi 90 1990 quattro 20v tornado red
