transmission out of wack.
Old 09-16-2015, 05:28 PM
mrprism133's Avatar
Default transmission out of wack.
i feel like my transmission shift points are off.
1st gear switches at 9mph
2nd gear switches at 17 mph
3rd gear switches at 25 mph
then the engine bogs down and i have to slam the peddle to maintain speed.
i drop the shifter to 3rd just to shift it when the speed is sufficient.
now to my question, is it possible to adjust the tranny shift points, and how..... thanks
Old 09-16-2015, 11:28 PM
CRAZY_RUSSIAN's Avatar
you trans needs a new filter and fresh oil, or a manual swap ;-)
Old 09-17-2015, 04:31 AM
grillage's Avatar
Manual Swap FTW!
Old 09-17-2015, 07:35 AM
mrprism133's Avatar
Originally Posted by grillage
Manual Swap FTW!
A manual swap sounds so good, however I live in jersey, don't have the space, and to be honest I don't have the expertise to take that on. I would love to have it done though.
Old 09-17-2015, 10:49 AM
i thing grillage has done a few, and i did one last winter. we found a donor FWD B4 for $400, it made life much easier and didn't have to worry about not having the right part.
but service your trans with fresh fluid and filter, Audi says that these transmissions have a life long fluid in them, which is total BS! autohaus az should have a filter with all the gaskets, also search the archives, one of the other guys did a nice write-up about it if my memory serves me right.
p.s. forgot to mentions, the automatic trans in cabs is total garbage. so if you decide that you want to keep your car, i would highly recomend doing the swap
Old 09-17-2015, 04:05 PM
grillage's Avatar
I've only done the one. A parts car would make this pretty darn convenient except for the exhaust part. It needs reworked around the transmission.
I did mine in my driveway if it helps. A garage would've been nice but not necessary.
Here's a thread on my car...
Ben's '94 Cabriolet build :: motorgeek.com
Old 09-17-2015, 07:15 PM
mrprism133's Avatar
i've seen this thread several times, and i must say that i'm very very jealous.. your cabbie is really nice!
Old 09-17-2015, 07:44 PM
I've had a lift and the owner of the cab helping me, took about 4 days and lots of inappropriate language and bloody knuckles . And yes, exhaust sucks and i would just take it to an exhaust shop for that
pictures https://www.facebook.com/customcarin...2903849&type=3
Old 09-18-2015, 05:10 AM
sanchius's Avatar
After putting 3 or 4 automatic transmissions in and having them all fail, I was ready to throw my cab away, but did the manual conversion as a last resort.
I should have done it years earlier, it turned it into an awesome car. <a href="http://forums.quattroworld.com/9080/msgs/47228.phtml">Here's all the stuff I've done with it since the conversion</a>
I put an ad in craigslist looking for a FWD Manual and someone gave me the black one. I put them up side-by-side on jackstands in the garage and did the swap.
It was a fair amount of work but nothing really hard. The need to fab up an exhaust was an unpleasant surprise at the very end.
<img src="http://farm6.static.flickr.com/5228/5623789577_c27ed4db95_z.jpg">
Here's the links I used (many of the pic links are dead):
B4 transmission / clutch DIY - AudiWorld Forums
transmission question. - AudiWorld Forums
B4CC into CQ writeup - AudiWorld Forums
Cabriolet 5 speed swap :: motorgeek.com
Cabrio Q nightmare project :: motorgeek.com
Hi MikTip question. - AudiWorld Forums
http://www.gowestyautoparts.com/1994...t/Front-Drive/
Watch specs on transmission fluid! It cost me. - AudiWorld Forums
http://www.bimmernut.com/forum/5-ser...plastic-2.html
Auto-2-Manual install complete! - AudiWorld Forums
quattroworld.com Forums: Audi mechanic advised I check 2 relays in aux. relay board before changing starter...
https://wiki.bentleypublishers.com/d...faqs/FAQs+Home
quattroworld.com Forums: Cab Transmission
Auto to Manual conversion? - AudiWorld Forums
quattroworld.com Forums: 80/90 Coupe + Cabriolet
Old 09-18-2015, 02:30 PM
mrprism133's Avatar
thanks for the info, it was very detailed and easy to follow.
Mesa512
S4 (B8 Platform) Discussion
20
07-07-2018 11:23 AM
Kerry G
05-18-2018 06:12 AM
Hours of Service
New Member Welcome Area
06-29-2017 05:07 PM
gorkyc
10-04-2015 07:00 PM
jonedwd
Audi A3 / S3 / RS 3 MKII
09-26-2015 10:49 PM
Quick Reply: transmission out of wack.
