Audi A2 Discussion forum for the Audi A2
Audi 100 Transmission shifts late
Old 04-12-2009, 01:34 AM
lisam's Avatar
Default Audi 100 Transmission shifts late
Hi, I have an '89 Audi 100. When it is very cold out (Canada) the transmission will rev out at 5000 rpm before it shifts. After driving about 20 minutes, it slowly goes back to shifting at normal revs. Likewise, if it is not cold out, it doesn't have this problem. I read on one forum that there is an adjustment cable, someone else said it was the transmission gaskets that leak, and swell when they are warm.
Sure would appreciate any help
thanks
Lisa M. Stewart
Old 04-13-2009, 05:19 AM
New Member
vandy07's Avatar
I believe that you should try to just heat up your car engine before going for a drive in winters.This is just warm up your car a bit.
Old 07-27-2009, 08:47 PM
Banned
koasdj's Avatar
I think you should try to heat up your car engine before driving. Hope this will help you.
Old 07-28-2009, 11:38 AM
advancedautomotion's Avatar
You have either sticky valves in the valve body or your pistons are sticking. Try changing fluid a couple times, or warm up the car first.
80AUDIS
12-17-2004 10:30 AM
andy rogan
12-05-2004 07:32 AM
red90q
12-06-2003 01:22 PM
Iain T
10-09-2003 11:08 AM
jeremySJ
11-20-2001 10:47 AM
Quick Reply: Audi 100 Transmission shifts late
