Last edit by: IB Advertising
- Audi A3 How to Install Backup Camera<br>Step by step instructions for do-it-yourself repairs.
$170 Reverse/Backup camera kit and install
#32
Just received this from Beijing just 10 days after ordering! Quality and condition of the parts are as good as stock. Installation wasn't too bad, I managed to work the wiring harness and control module out of the way without needing to remove the 7 bolts on the glove box, probably wouldn't be possible for someone who has large hands though.
I have the NON-NAVIGATION MMI with the smaller 5.8 inch screen and can confirm that switching the #2 switch to ON adjusts the screen size to work correctly. I chose to leave the IPAS guidelines on and turned off the radar sensor display. The only thing I'm unsure about is the English/Chinese language setting because I think it is cutting that part of the screen off, so no text shows at all. Overall very pleased with this camera, it's totally worth it!
#33
Hi Washingtonian! I like that you are a GM guy too!
I assume non-MMI unit is smaller than MMI unit. There is no way my MMI unit can hold both unit and adapter in there.
But glad you like it. I love it every day when I back up.
#34
Surprisingly, the two units appear to be the same size (after looking at the images on the first page).
There is that opening in the back right corner of the mmi enclosure.. I pushed the control module back into that space and fed the harness toward that corner while elevating the non-mmi unit. Then I used the non-mmi unit to push the harness back into that space as well. It took a lot of careful persuasion and had to use more force than I would have liked, hopefully that just means it won't rattle around haha.
#35
Yep I love GM vortec V8. I am pushing around 400+HP with just bolt on mods. The 4 door GTO runs about 12.8sec 1/4mile. Fun car.
Ok, you pushed to the hole space without taking apart. That is where mines at too. I took globebox apart, so it was easier to pull them from back.
#37
The handle does not fit the a3 cabriolet... I'm currently having my car and camera cut apart by a custom audio shop as they're going to try fitting the camera to my bumper. I'll post pics later. They're also going to be doing a sub install later on.
#39
Quick questions: does the display automatically show the rear camera when the car is shifting into Reverse? And does the new trunk handle still allow for the "touchless" unlocking?
Many thanks!
Many thanks!
#40
Yes, the rearview camera is automatically displayed whenever the car is shifted into Reverse. Then disappears when shifted into Park or Neutral. The new trunk handle operates exactly the same as stock. Opens using the key fob or the slightly smaller release button on the trunk handle next to the camera lens. Functions perfectly.
Blkstallion (10-06-2021)
