Last edit by: IB Advertising
- Audi A3 How to Install Backup Camera<br>Step by step instructions for do-it-yourself repairs.
$170 Reverse/Backup camera kit and install
#261
This is fantastic that you are making progress with your camera quest. This is the A3/S3 subforum though, and while this information is useful to you, it might confuse those who are coming here for information for their -3s. You should start a new post over in the A6 section with what you found here and your install!
#262
Ordered and install my camera. Stuffing that unit into the glove box was not the easiest thing, actually a swift pain in the .... But very satisfying when done. Thank you all for the posts, I read every post this morning took notes and the install went as well as could be expected, no surprises, thanks again everyone.
One question, I still am having a really tough time tucking the wire under the trim alongside the passenger seat, can't seem to pry the panel up enough to tuck it under ( hard to get my fingers down there due to the seat rails) Are you folks actually removing the plastic panels along the B pilar or just sliding the wire under?
Thanks in advance
Jonathan
Thanks in advance
Jonathan
#263
Thanks in advance
Jonathan
Thanks in advance
Jonathan
#264
#266
Ok followed the guide and took about 2.5 hours to install. The biggest pain was to put the MMI back in since I had to figure out how to stuff the camera box in with it.
Camera works fine, but when I'm going reverse the music mutes and then either in park or drive, the music comes back on. Is that normal?
#267
#268
FWIW, I pulled down the glove compartment to do the install and put all the backup equipment in on top of the glove box, if that makes sense. Not in the little pocket where the MMI gets inserted. There is ample room up there and nothing had to be shoved/stressed. 16 months in and haven't had an issue.
#269
#270
2015 A3 Covertible question
Have the problems installing the backup camera in a convertible been solved? Do the supplied instructions cover it? Also need info re the trunk release problem. Have reviewed ALL the info on this discussion looking for an answer.
Appreciate hearing from anyone who has successfully made the install. Details etc. Have NoNav MMI.
