2016/17 Map Update Available
A new update is available on the my.audi.com listed as a 2016/17 map update.
Good luck. Make sure you have Java to download.
Were you able to actually download the maps? There have been a couple of threads on this and everybody seems to be having trouble getting past the login screen. I just tried again and no joy.
I have tried several times and as of yesterday I still couldn't download the update.
I was able to get access to my.audi.com by logging into my.audiusa.com first. Then I clicked Audi connect services, then clicked on the image of my car, then I was able to access the Map Update section.
Edit: Oh... login screen on the actual Audi Java downloader app... Yep, it's not taking my credentials.
Edit2: From AudiChat --
"Thank you for chatting with me today, sdjaime. At this time, this is a known concern. We are working to correct it, currently. There will be some myAudi maintenance tonight and tomorrow which may correct this, however, I can not gauruntee that this will be the case. We would recommend checking back every few days to see if it is complete."
I had same problem as sdjaime. You would think someone from AudiUSA would check to see this is working before putting into production. Try again tomorrow...
