D vs. S transmission behavior
I have an A3 2.0. I am learning the behavior of the car.
I like the behavior of the car when the transmission is in S mode. It holds higher RPMs before shifting. But one thing I do not like is that it chooses a lower gear at steady highway speeds. That doesn't make sense to me. If I am driving at 60 MPH, and switch from D to S mode, it clearly downshifts to 5th instead of 6th. Does that make sense?
S mode is designed to not only hold the gears longer when upshifting, it also maintains the lower gears longer in deceleration and cruising to provide a quicker on-demand response to the accelerator for "sporty" driving. As a result, in most Audis with an auto transmission, the transmission will drop 2 gears when placed in S mode. In my A6 8-speed tiptronic, it will not even upshift to 8th gear when in S mode on the highway.
I just go to manual mode and use the paddle shifters. I put it in 6th on the highway and it stays there untill I hit the downshift paddle twice to get to 4th for a quick pass.
And as already pointed out - I can either go to paddles or shift to D if I want 6th for highway driving.
Except for a jumpy throttle at certain low speeds, the DSG with the sport package is outstanding.
S to manual different from D to manual
