Audi A3 / S3 / RS 3 MKII Discussion forum for the 2015 to 2022 Audi A3, S3 and RS3 - including the upcoming E-tron and TDI models
Disabling headlight washers in vagcom
Old 12-13-2014, 12:10 PM
dlmmail18's Avatar
Default Disabling headlight washers in vagcom
Wondering whether anyone has had any luck disabling headlight washers in vagcom.
I've seen a thread on vortex that lists out many of the 8V VCDS mods, one of which is adjusting SWRA (headlight washer) settings.
However, I am having trouble understanding what the code actually does - it seems to suggest that it adjusts frequency not enable/disable.
Furthermore, it looks like the code has not yet been tested.
Anyone have any luck or hear of any others trying this code? Tired of getting my nice wax and wash marked up by washer fluid spraying on the hood.
I've copied the relevant portion of the thread below in italics, but wasn't sure whether linking to other forums is allowed.
Adjustment of the interval of the headlamp cleaning system (SWRA) - NOT TESTED
[09] Central Electronics -> Adaptation ->
Channel (1) - Number of operations front windshield wipers wash per SRA activation – Set value
Channel (3) - windscreen wipers SRA washing time – Set value
Old 12-13-2014, 05:15 PM
DennisMitchell's Avatar
Record your initial values. You could try raising and lowering the values. Try a high value, then a low value. The headlight washers come on only when you continue holding the wiper stalk in the washer position longer, so it is logical adjusting the interval before head light washer engages. I hope someone else have better info.
Old 12-15-2014, 09:47 AM
OOOO S3's Avatar
+1 I would like to have this confirmed as well.
Old 12-15-2014, 12:19 PM
drober30's Avatar
Does the S3 have headlight washers?
Old 12-15-2014, 01:59 PM
OOOO S3's Avatar
yes they do.
Old 12-15-2014, 03:51 PM
drober30's Avatar
I always thought those were gimmicky. I do like the fact that the washer nozzles are heated.
Old 12-16-2014, 05:10 PM
gamegenie's Avatar
I haven't even used the windshield washer fluid on my wipers yet to even activate the headlight washers.
jdemocker
04-01-2022 03:01 PM
parryj
A6 (C7 Platform) Discussion
02-20-2016 10:07 AM
samps
Q5/SQ5 MKI (8R) Discussion
12-25-2014 01:38 PM
CanadianQtip
S4 (B8 Platform) Discussion
02-23-2011 04:21 PM
lowbee
VAG-COM Discussion
04-17-2006 08:29 AM
Quick Reply: Disabling headlight washers in vagcom
