:: ECS Tuning :: 8V S3 APR Turbo Muffler Delete
Audiworld Basic Sponsor
APR has developed a simple method of bypassing your restrictive factory turbo muffler with a single billet aluminum piece.
The Turbo Muffler Delete eliminates the vented OEM muffler tube, allowing air to pass uninterrupted through the compressor outlet. This dramatic increase in air flow allows the turbo to operate more efficiently while enhancing the sound characteristics of your engine.
Now available for the Audi 8V S3, this latest APR release is a simple, highly effective upgrade for your Audi.
Hit Delete...
Click HERE to order or for more information
Fits:
Audi 8V S3 (2015)
Let me know if you have any questions.
Jason
For what purpose would Audi have vented the OEM pipe not made a solid section as the APR? Understand the airflow would be better with the APR but trying to find out a real advantage to changing the parts. Also not sure how difficult it is to swap out. Location dependent of course.
Am really digging my ECS wheel spacers however!
The APR unit simply blocks the redirection ports which gives the compressed air a straight path right into the intake ducting. This does two things. 1) Increases spool up response as the air has a shorter freer-flowing path into the intake. 2) Allows the turbo to be more audible.
I hope this helps! Glad to hear you're enjoying your spacers!
Jason
The turbo muffler on the compressor cover outlet is just that. A muffler. It keeps the turbo spooling sound to a minimum by redirecting some of the air flow. Not everyone appreciates the spooling sound of a turbocharger. And for those that are unfamiliar with a turbocharged vehicle the noise may strike them as an issue with the vehicle.
Jason
Jason
Need to get under the hood to see how easy it would be to access and replace this piece however. Looks straightforward.
Thanks for the most excellent description Jason! Makes perfect sense. Getting to hear my turbo a bit more certainly would not be a problem. Assume APR unit would theoretically make the engine more efficient overall.
Jason
Ah, but there is probably a difference in depth. It looks like the APR part is actually 2 pieces, with one that threads in to remove any gap between it and the turbo outlet - closing off the muffler volume completely. I was curious how they would manage that tolerance stackup. With the 2 piece set up, you don't have to manage it....
Glad I could help! Installation is very straight forward. Although you are constricted a bit due to the turbocharger being mounted on the backside of the engine near the fire wall, but once you locate the compressor cover exit it's very simple. Begin with loosening the outlet hose clamp, then remove the hose from the compressor cover, next remove the 3 OEM muffler/baffle screws. Once you've done this you'll slide out the OEM muffler/baffle. Now you can install the APR piece. Then just reverse the removal to get everything reassembled!
Jason
Jason
ECS Tuning-Audi
Audi A3 / S3 / RS 3 MKII
10-27-2017 07:28 AM
ECS Tuning-Audi
05-18-2016 01:05 PM
ECS Tuning-Audi
A4 (B8 Platform) Discussion
05-18-2016 01:05 PM
Audi A4 B8 APR Turbo Muffler Delete
SVtracker
10-25-2015 03:25 PM
ECS Tuning-Audi
08-13-2015 01:13 PM
