installing fog lights in an A3?
If there is space in the outboard ends of the lower grille, I'd recommend the Hella Micro DE projectors, which are optically excellent. They were recommended by Susquehanna Motorsports (bigtime SCCA Rally supplier back when SCCA sponsored it) for my Saabaru when I wanted deer spotters and I've found them excellent. I wish I could retrofit them into my UrS, but that would be very difficult and they can't be put into the lower grilles due to airflow to the IC and Oil Cooler.
The lamps themselves are now on Amazon or Eflay for WELL under $200 for the pair. Since I'm fairly certain that the wiring harness is the same for all models, all that is needed is a factory switch, let's be real generous, 2 clock hours to physically install and maybe 10 min with VAG-COM to get CAN-BUS to recognize the lamps and monitor (or perhaps the opposite) so even in a high labor location(~$90/hr?) you're looking at <$400. Or DIY for probably ~$200 (genuineAudiparts.Com prolly has the switch for ~$100) and find a local bud with VAG-COM to do the programming. Depending on a shop to do everything = keep it stock.
Audi Other FS: 2007 Audi RS4 black/black CCW
ilikeit
01-09-2016 09:24 AM
carl viking
09-05-2015 05:31 AM
