Is this noise normal?
I just bought a used A3 2015 last week. I'm hearing some noise in the car when I turn the engine on. Its not loud enough to be able to hear when I'm driving but I wanted to know whether this is an issue. I still have a few days where I can return the car to the dealer..
Here is a video recording of the sound I'm hearing:
You can keep and deal with warranty, but could be long term issues after warranty. CPO car? Extended warranty?
Are you taking about the ticking or the somewhat low level knocking noise at the end of the video? Knocking is concerning. Sounds premature and I'd have another dealer look at it and then bring it back to the one you bought it from if they suspect a problem.
Bought my car on Beepi.com (10 day money back warranty)
I am just a shade tree mechanic and new to the Audi but that does not sound normal. It does not sound like lifters but I would check the oil level to make sure. It sounds like a bearing is about to go on something.
Thanks!
Hydraulic lifters are self-adjusting. They will tick when something causes them to lose their internal oil pressure or sometimes the case is that you are really low on oil.
The bearing is a different issue. Bearings are used all over the motor, basically anything that spins has bearings in it. The fun is finding which part is causing the noise. Alternators, and Water pumps are usually the main ones.
Quattrp
A4 (B8 Platform) Discussion
04-08-2022 01:59 PM
Audi Convert
A6 (C7 Platform) Discussion
01-19-2016 08:00 AM
