Rear LED fog lamps from deAutoLED installed- Error Free!
Hey I wanted to share these new Red LED Rear Fogs that got for my s3. The beam pattern is more evenly spread, they run cool, and will last for a very long time.
Stock against the garage is on the left while the LED's are on the right
Now my rear tails are FULL LED
Contact deautoled@gmail.com to get a pair!
The LED fog is cleaner (Less star burst glare created). While the Stock fog bleeds into part of the brake light and creates a star burst glare effect.
Not to mention I nearly burned myself pulling out the stock rear fog. it was extremely hot after being on for maybe 15-30 seconds only...
go with the LEDS much cleaner, cooler, better, longer lasting.
TIA!
Kevin
They are about 30-40 if i recall correctly. Install is very easy. Only takes 30 seconds per side.
Use a screw driver to pry open the cover. Then unclip the 3 clips holding the bulb to the housing. Push bulb in and twist to remove. Reverse to install.
Thanks for the interest, the rear fogs are almost here and in stock!
We will get a listing/pricing up soon - do people normally buy with with 1 reverse or is the fog separate on this model?
Thank you
Thank you
Ok thank you.
We will get a 2 LED kit for the fogs.
We can do an intro price of $39.99 - final price will be $44.99 for this model.
w:http://deAutoKey.com
-Error Free LEDs for your Audi (interior & exterior)
f: https://www.facebook.com/deAutoKey
i: http://instagram.com/deAutoLED
I will get some pricing from the deAuto Team and see if they want to hold a combo sale for a few weeks.
