Retrofitting: Audi Drive Select (Kinda retrofit)
#41
Ironically if I put the car in neutral while coasting, MPG overall goes up (calculating via tank and not the MFS).
#42
Also the 8V0063765 picture online (ebay and one at http://www.hahn-onlineshop.de/zubeho...lenker/a-6633/) shows zip ties, harness and some square things. Can you explain what those are? Is there more than one drive select button that comes with this retrofit kit?
#43
So Just to confirm, you were able to have a dealership (one in SF I think you wrote) activated the new hardware (the button) and code the vehicle to it, after you installed the hardware (harness and button). Is that correct? I ask because I've found dealers typically won't warranty the work someone else did.
You don't need the ADS button, but the wire basically is to connect it to the ECU module. Basically what you really need is the activation code which is tied to your VIN when you order the kit. This kit does not come with a new center console button unit, you will have to buy that separately.
#44
mroberte, I bought a console switch that has a "Drive Select" button and I bought the retrofit kit from hahn-onlineshop.de via ebay. A couple online US Audi dealers told me they weren't able to buy 8V0063765 retrofit kit. I'm in the Sacramento area and there's a repair shop in Auburn that has the Audi VAS software to be able to adapt hardware to cars. I'm hoping they can perform the adaption.
#45
#46
Mroberte, when you write "you have the code too?" does that mean a code comes with the retrofit kit. Yes, I agree that the download comes from Audi but I believe Audi authorized VAS users (like one in Auburn) don't necessarily have to be Audi dealers. I will of course confirm once I finish this experiment.
#47
#48
Ok, received item 8V0063765 from Germany ($225 shipped). It is indeed a single, 2-wire bundle, tie wraps, instructions, and an activation code/proof-of-purchase document. Next I'll install the console switch that I purchased separately, install the harness, and take it to my local, authorized audi repair shop to activate the Drive Select.
#49
Update: I installed the wire harness and inserted the pins into the harness connectors as specified by the instructions. It was fairly simple but it's never enjoyable to remove plastic panels, even with plastic tools designed for interior work (harbor freight) since there's slight risk of tabs breaking or metal springs flying off.
Then I installed my new switch panel which I did not see is missing the "passenger airbag" lettering and light. This caused a yellow passenger airbag light to come on the dash. I think the ECU is looking for the LED that lights up that lettering and it's not there. Now I'm back on ebay looking for the proper switch panel. There are plenty out there but some don't have that passenger airbag led. I considered desoldering the led that's on the board inside the switch panel and soldering it to my new one but I'm not good at soldering and the risk to me outweighs the reward. It's a tiny led.
Appt to code the new software to the car is next week.
#50
First time I took the car apart it was very nerve racking too. Glad you'll have the ADS soon!
