Audi A3 / S3 / RS 3 MKII Discussion forum for the 2015 to 2022 Audi A3, S3 and RS3 - including the upcoming E-tron and TDI models
S3 wouldn't get into gear from stopped
Old 05-04-2016, 12:50 PM
ayn
ayn's Avatar
Default S3 wouldn't get into gear from stopped
Yesterday, driving in manual mode, I accelerated to pass a car and then braked at a stop sign to a complete stop. When it was my turn to go, with transmission in M1, I pressed on the gas and nothing happened. I shifted to A, nothing, tried S, and same thing. I finally had to switch off the car and turn it back on with the start/stop button, and it would get into gear and move.
Is this a common problem? Seems super sketchy to me, lucky I was not at a busy intersection when that happened.
Old 05-04-2016, 07:18 PM
will13k7's Avatar
~12k miles, never ran into that.
Old 05-05-2016, 06:36 AM
Fixeroh's Avatar
Ouch. That would be pretty un-nerving I'm sure. Glad you got it cleared. I had a power loss while driving one day. Car just wierded out. Pull to the road side, shut down and restarted. Was perfectly fine and never did it since. Hope it was just a fluke. Too many microchips and microcircuits. I work in the electronics field and the stuff definitely isn't perfect unfortunately.
Old 05-05-2016, 04:39 PM
arU4ic's Avatar
When you say "nothing" you mean no forward motion or really nothing? No RPM increase?
Old 05-05-2016, 04:40 PM
ayn
ayn's Avatar
Car did not move, engine did not rev, RPM did not rise. Like the accelerator did absolutely nothing.
Old 05-05-2016, 04:55 PM
arU4ic's Avatar
Yikes. Sounds like it's running Windows - you had to turn it off then on again.
Seriously though, sorry... just that one time?
Old 05-05-2016, 04:56 PM
ayn
ayn's Avatar
Yes just once so far, but I have under 150 miles on this car.
Old 05-05-2016, 10:19 PM
arU4ic's Avatar
I'd take it in and have it scanned (or if you know someone with a VAGCOM cable do it yourself)... mostly likely it kicked out errors.
Old 05-06-2016, 05:28 AM
Fixeroh's Avatar
^^^arU4ic is quite right. There should be a record of the errors generated. Audi service department definitely should be notified. Especially considering the low mileage.
Old 05-06-2016, 07:25 AM
ayn
ayn's Avatar
Ok I'll pull the errors and see.
@arU4ic since you're in SF too, which dealership in the bay do you go for service?
Quick Reply: S3 wouldn't get into gear from stopped
