S3 wouldn't get into gear from stopped
Yesterday, driving in manual mode, I accelerated to pass a car and then braked at a stop sign to a complete stop. When it was my turn to go, with transmission in M1, I pressed on the gas and nothing happened. I shifted to A, nothing, tried S, and same thing. I finally had to switch off the car and turn it back on with the start/stop button, and it would get into gear and move.
Is this a common problem? Seems super sketchy to me, lucky I was not at a busy intersection when that happened.
Ouch. That would be pretty un-nerving I'm sure. Glad you got it cleared. I had a power loss while driving one day. Car just wierded out. Pull to the road side, shut down and restarted. Was perfectly fine and never did it since. Hope it was just a fluke. Too many microchips and microcircuits. I work in the electronics field and the stuff definitely isn't perfect unfortunately.
^^^arU4ic is quite right. There should be a record of the errors generated. Audi service department definitely should be notified. Especially considering the low mileage.
