Should I buy winter tires?
#21
Yeah I like that but the pricing would be high because there aren't much 19" winter tires in the market. I checked the pricings and if I purchase a new set of 18" wheels and winter tires it would be cheaper and my OEM wheels will be safe from the salts on the road.
I'll probably just buy a set of wheels and give them to Costco to install Michellin Alpina PA4 winters for me.
#22
Finally ordered 18" replicas with Michelin Alpin PA4, $2,100 Canadian all-in.Will post pictures when I get them installed.
Just a question, it has 35+ offset, does that work ? My trustee at Kaltire says it does.
#24
So here it is ! 18" X 8, offset is 38, and they were $155 a piece at my loca Kaltire with discount. Tires are Michellin Alpin PA4 225/40R18. The cost me $2,200 Canadian all-in.
#25
How do you all handle the tire pressure sensors? Talking to my local tire guy about 18" wheels/all season tires for the winter (S3 w/ 19" ordered) and he mentioned he could add the sensors but not program them?
#26
Suggest you get in writing that what they supply will be compatible with your car's sensor system. The current pressure is set via the MMI settings menu. Your manual will give you details on that. It has to be reset when you change tires and/or add pressure. The people who installed my tires could not figure out how to reset the monitor. I went back the next day thinking I had a leak but the cause was that they did not reset the monitor system.
#27
The cars manual describes how to reset the TPM system.
#28
I don't think we get that on Canadian version of S3. I have a 2016 S3 Tecknik full option but on MMI nor any other places I can find a setting for resetting the TPMS. Even when installing winter tires the tire shop said My car doesn't have it.
#29
It is in your manual. The TPMS has to be reset whenever tires are changed or pressure is changed (usually the fall)
#30
Personally I would suggest any Canadian S3 owners to call their dealer service adviser and ask them to confirm either way.
Good Luck and let us know how it goes !!!
