VAG COM VCDS with the WiFi adaptor
Does anyone have the WiFi version of the VagCom?
Would you recommend? Does it support all the regular functions? How easy to use??
Would be awesome to have this device and use my ipad to change settings...
Almost seems too good to be true.
Ross-Tech Store: VCDS License with HEX-NET (WiFi/USB) 10 VINs (All VAG)
@4-500$ seems worth. Prob gonna pull the trigger on this for my s3 but thought Id check in to see if anyone else has use it.
cool! order placed. will be tinkered with some of the basics first: seatbelt chime removal, Comfort window closing, and maybe the wink disable.
Then I will step it up and get my gear indicator and oil temp display in the dash. Maybe TRY hill hold...
So I ordered the WiFi adaptor with 10 licensees(next dayd) and already downloaded the VCDS from the app store...
Also this weekend hooking up the center screen to mirror my phone. should be fun labor day weekend
My first mod was a huge success. Got rid of that damn seatbelt beeping AND the light. I feel like such a hacker!
if your looking into one of these you will be doing some troubleshooting... but it pays off
some of the predefined actions did not work for me so i had to go in and change a digit in a huge long list of code. luckily it was the 2nd digit changed from a b to a 3.
win!
win!
negative. so far successfully removed the seat belt chime and light, parking beepers turned off, comfort closing added ( and sunroof), decided against doing the wink
There seems to be no options in the 02 Auto Trans module. My code is literly 0014. The only adaption is a rolling test mode.
Going to post on the Ross Tech forums and figure this out.
I have a feeling the tuning for this is in some other module. Maybe one that vag come is not aware of yet..
S6Express
A6 (C7 Platform) Discussion
01-29-2022 04:31 AM
bballfreak
9
04-14-2019 06:59 PM
iamdrewseph
10-01-2015 11:33 AM
