Last edit by: IB Advertising
- Audi A3 Brake Modifications and How to Replace Brake Pads<br>Overview of popular modifications and how-to.
What VAG-COM Mods are suggested?
#13
I have searched several sites for this one but have come up empty.
This mod would definitely improve night driving.
Thanks a bunch!
#14
For me this caused a MIL something about Audi Adaptive Lights and calibration. But I was able to get around that by going into Channel 55 > Basic settings >select Basic Headlamp setting in drop down> click go>click stop> select Acknowledge Basic Settings> Go> Stop
Then reset the fault codes. You shouldnt have to do this and I dont know why mine did but just in case. (maybe because i have euros with a NA car) either way i get the functionality and no more errors.
#15
Were you driving out of PB on Garnet yesterday, by chance? I think I may have seen you. Don't think there are many blue S3's in town.
#16
But yeah I've only seen one other blue S3 around town, but I'm sure there are a few of us.
#17
Codes?
Hey MarkN,
You don't happen to have the actual coding for your mods handy to post here or PM me do you? The shop I'm going to can do the basic VAGCOM mods like rolling windows up/down, but they said anything more then they'd charge me for the time it takes them to look up the codes and test them etc. Could become pricey.
Any of the ones you may have handy to write down would be much appreciated. Thanks!
#18
Hey MarkN,
Disable DRL's in Light Switch 'O' Position -
[09] Central Electronics -> Adaptation ->
(9) Tagfahrlicht-Tagfahrlicht nur in Schalterstellung AUTO
CHANGE: Set Active
Set Oil Temperature on all DIS Menus -
[17] Instruments -> Long Coding -> Byte 10
CHANGE: Tick Bit 1. Display Oil Temperature
Disable seatbelt warning - TESTED AUDI A3 1.2T ‘13
[17] Instruments -> Long Coding -> Byte 0 ->
CHANGE: Set bits 2-4 using combo box
Comfort Closing of windows/sunroof
09-Cent. Elect
Security Access – 31347
Adaptation – 10
(2)-Access control 2-Comfort opening – make Active
(3)-Access control 2-Comfort closing – make Active
(7)-Access control 2-Funk Komfort oeffnen – make Active
(6)-Access control 2- Funk Comfort schliessen – make Active
(27)-Access control 2-Menuesteurung Komfortbedienung einstellbar – set to Adjustable
couldnt find the code for the rear DRL's- it might be on my other machine (in the garage)
there is also a new code i found for auto closing the windows if rain is detected
how much are they charging you for the vag com mods?
i remember back in the day we bros helped each other out with this kind of stuff. and if you are in SD id love to help for free
