Last edit by: IB Advertising
- Audi A3 Brake Modifications and How to Replace Brake Pads<br>Overview of popular modifications and how-to.
What VAG-COM Mods are suggested?
#21
@Tsyndr ... Like MarkN, I'm also in SD, have a cable, and am happy to help with the coding...
Here are a few others you may be interested in. I did run into some issues with the word being slightly different than listed below, and kept a pretty good record on my laptop at home. I can reconfirm these if necessary tonight.
Mirror dipping function
[52] Door Electronics, Passenger > Long coding > Byte 04 > Set bits 02 and 03
Need 5Q4 959 592, not 5Q0 959 392 B (I think)
Visual confirmation of comfort closing
[09] Central Electronics -> Adaptation ->
Acknowledgement Signals – Comfort closing ack??? (need to check it back)
CHANGE: Set Yes
Front DRL and turn signal out of phase
Select STG 09 ( Central elec)
Access Security -> 31347 -> Login
Adaptation 10. Change the following values:
(16) Leuchte2SL VLB10 - LichtfunktionG2 to " Blinken links Hellphase "
(18) Leuchte2SL VLB10 - Dimmung GH2 to "0"
(16) Leuchte3SL VRB21 - LichtfunktionG3 to " Blinken rechts Hellphase "
(18) Leuchte3SL VRB21 Dimmwert GH - 3 to "0"
The windshield wiper service via MMI (you mentioned to me in a PM) and the rear DRL setting can be found in this guide: VCDS Adaptations and Codings for the Audi A3/S3 8V Range
CHANGE: Set Yes
#24
Great Coding Write-up
I forget exactly who shared this with me but this write-up is well done. The author is on the cover page.
https://onedrive.live.com/redir?resi...int=file%2cpdf
#25
DRL Blinking out of phase and Mirror Dip
Hi Guys,
Can someone confirm that these two VCDS mods work without any issues on a 2016 A3 Quattro?
Did an auto scan and I have 5Q0 959 592 B door module installed.
thanks in advance.
thanks in advance.
#26
Thanks MarkN and sdjaime, the shop was able to complete most of the VAG mods I wanted and they didn't even charge me! (forgot?) I think because I provided the codes they didn't really charge me since they didn't have to do much (Thanks guys!).
#28
Anyone in NY area or long island with vag com willing to help me out with some mods or knows a shop that has it. My dealer which my car is a month old 2016 A3 Quattro premium plus doesn't do anything for me
#29
Mods
[QUOTE=Jjc23;24807529]Anyone in NY area or long island with vag com willing to help me out with some mods or knows a shop that has it. My dealer which my car is a month old 2016 A3 Quattro premium plus doesn't do anything for me[/QUOAdd
Ditto for anyone in the N.C. area.
#30
Disable DRL's in Light Switch 'O' Position -
(9) Tagfahrlicht-Tagfahrlicht nur in Schalterstellung AUTO
CHANGE: Set Active
Set Oil Temperature on all DIS Menus -
[17] Instruments -> Long Coding -> Byte 10
CHANGE: Tick Bit 1. Display Oil Temperature
Disable seatbelt warning - TESTED AUDI A3 1.2T ‘13
[17] Instruments -> Long Coding -> Byte 0 ->
CHANGE: Set bits 2-4 using combo box
Comfort Closing of windows/sunroof
09-Cent. Elect
Security Access – 31347
Adaptation – 10
(2)-Access control 2-Comfort opening – make Active
(3)-Access control 2-Comfort closing – make Active
(7)-Access control 2-Funk Komfort oeffnen – make Active
(6)-Access control 2- Funk Comfort schliessen – make Active
(27)-Access control 2-Menuesteurung Komfortbedienung einstellbar – set to Adjustable
couldnt find the code for the rear DRL's- it might be on my other machine (in the garage)
there is also a new code i found for auto closing the windows if rain is detected
how much are they charging you for the vag com mods?
i remember back in the day we bros helped each other out with this kind of stuff. and if you are in SD id love to help for free
CHANGE: Set Active
09-Cent. Elect
Adaptation – 10
Hey Mark did you ever find the code to turn on the Rear DRLs? Thanks
