Audi A3 / S3 / RS 3 MKII Discussion forum for the 2015 to 2022 Audi A3, S3 and RS3 - including the upcoming E-tron and TDI models
Old 08-09-2016, 11:41 AM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Audi A3 Tire Repair and Maintenance
Print Wikipost
Winter Tires
Old 10-04-2015, 07:12 AM
RYYC's Avatar
Default Winter Tires
Hi guys,
Picked up my new 2015 A3 just in time for winter.
I found a used set of 19inch A4 S-line for a good deal.
(19x8.5 - offset / et 43. 5x112 bolt pattern)
Do you guys know if these fit with no clearance issues?
Old 10-04-2015, 07:57 AM
DennisMitchell's Avatar
No clearance problems, but if there are potholes in your area, I would not go with 19" wheels. You should go with 17 or 18".
Old 10-05-2015, 08:32 AM
Antarius's Avatar
Depends on where you live, wheels will fit with no problem, but I enjoy having a 50 profile 17" tire to survive early spring in Cleveland.
Old 10-05-2015, 10:46 AM
daves4's Avatar
FWIW, even with 18" all seasons, the potholes in New Jersey were up to the challenge and blew a tire on me anyway.
Old 10-06-2015, 04:53 PM
cheewy's Avatar
the hub on the A4 is 66 vs 57 on the A3. I think you would need hubcentric rings to make them work.
Old 10-07-2015, 03:33 AM
Storm982's Avatar
I'm in the Akron, OH area. Went with 17in ones as well.
Old 10-17-2015, 09:41 AM
RYYC's Avatar
Thanks for the help.
Decided on a 17in.
Found a old set off a A6
Alloy rims from 2008 A6. - fits 225/R50 17 tires
Size:7.5J x 17 ET42 (offset +42 mm).
Bolt Pattern (PCD): 5 x 112
Thread Size (THD): M14 x 1.5
Center Bore (CB): 57.1 mm
Anyone know if this will fit on my 2015 A3?? I think it should
Old 10-17-2015, 12:07 PM
Decided on a 17in.
Sounds perfect.
markN1689
09-12-2015 02:29 AM
Quick Reply: Winter Tires
