Audi A3 / S3 / RS 3 Discussion forum for the 8L and 8P Audi A3 S3 and RS3
AUDI A3 2005 cd player/interior change
Old 07-26-2016, 12:16 PM
MatasCek's Avatar
Default AUDI A3 2005 cd player/interior change
Hi guys,
I just want to ask you if its possible to change from this control panel (foto nr.1) to this (foto nr.2). If yes, then what parts should i buy and what else should i know about doing such changes.
Nr 1
Nr 2
Old 07-26-2016, 12:17 PM
MatasCek's Avatar
Nr1
Nr2
Old 07-26-2016, 12:55 PM
kaotik1's Avatar
the issue is going to be mating ECU to the new head unit. Your gonna need a VAG COM cable to access the ECU to make the connections and info routing work. I've had these systems in the past. But yes...you can retrofit this unit in. I think you'll need to swap the amp out as well. How the sound is distributed is different.
Old 07-26-2016, 01:17 PM
MatasCek's Avatar
My english is not very good, can you please explain what 'How the sound is distributed is different' means ?
Old 07-26-2016, 03:17 PM
kaotik1's Avatar
In figure NR1, the tweeters and the mid ranges are wired together to and from the amp...in figure NR2, the tweeters and midranges are connected separately. You can piggy back the connections like most do...but it sounds crap. It's better to get the amp and head unit together, and just rewire the speakers.
BTW..the amp is in the quarter panel on the right hand side...
bob m
Q5/SQ5 MKI (8R) Discussion
14
04-19-2014 02:27 PM
bl@ck
VAG-COM Discussion
04-24-2007 10:11 AM
SDR
Audi A3 / S3 / RS 3
12
11-30-2005 06:38 AM
ph0ust
VAG-COM Discussion
08-08-2003 01:46 PM
RalTT
01-15-2003 05:56 PM
Quick Reply: AUDI A3 2005 cd player/interior change
