Card tray removed. Cup holder installed.
#24
V1 display MAY WORK!!!!!
<center><img src="https://store.valentine1.com/store/products/20110hb.jpg"></center><p>
The height of the tray is close to 1".
The V1 display is 1" tall!!! WOW x 2.5" W x 1.2" D
The Concealed Display may be attached directly to the Lighter Adapter (see Note below). Or you may mount it anywhere using self-stick interlocking fasteners, then connect with the power cord (included) to either the Lighter Adapter or Direct-Wire Power Adapter (both included with V1).
Mute and Mode selection are controlled by the Control **** on the Display (On-Off and Volume adjustments remain on V1).
This compact module measures only 1.0-in. H x 2.5-in. W x 1.2-in. D. Satin-black finish matches V1.
Note: This "attachment" is not possible with the old single-wire Lighter Adapter used up through 1997. Replace with post-1997 Adapter (Item 20314) as used on today's V1.
Includes: Concealed-display module; Power cord, 8-ft.; Power cord, 3-in.; Display-module backplate (for mounting); self-stick interlocking fasteners.<ul><li><a href="http://www.valentine1.com/moreinfo/ConcealedDisplay_pg18-19.pdf">V1 display link PDF</a></li></ul>
LarryK1000
11
12-10-2002 04:42 PM
changs4
08-27-2001 06:09 PM
