Nav+ (RNS-E) and Bluetooth Retrofit: single-DIN to double-DIN conversion
#31
Very nice! It is crazy how expensive it was to change it to Double DIN compare to now a days.
I'm thinking about getting a double DIN unit with android. There is a huge growing community for developers to get more out of the head unit at XDA forums.
$189 perk of OctaCore Android head unit for … | Android Auto | XDA Forums
#32
thanks for your detailed description in the original post, I followed your guidelines today to remove & replace a "chopped-up" single DIN from a Japanese import with a Japanese language NAV - toughest part as you said was removing the current cage.
#33
links don't work
Links to adapter don't work. Does anyone know where I can get the adapter ? In my 8P A3 I'm going from single DIN audi concert non-bose radio to double DIN Audi RNS-e. I already have double din cage, rns-e, card drawer, hazard, climate control etc...Only stuff i'm missing is Audi concert to RNS-e adapter, GPS antenna, Bluetooth unit, microphone.
Back up camera and wiring if these units came with it.
Any links/Help is appreciated
Any working links to the radio adapter to work with non-BOSE, GPS antenna and Radio antenna adapter ?
aku.jmer (03-28-2023)
#35
Can any one in London (UK) do this for me? I'll pay £100. I have all the parts. Double din cage and buttons. All i need is someone to fit the cage, buttons, my navigation system and trim the climate control. Email me on: juned90@hotmail.co.uk if anyone can do this. I will travel to you if you are in london
#36
Just want to add a few things of note here... even though the number of people doing this is a far cry from years ago.
- Double-DIN cage alignment. NOTE... that this cage doesn't have a 100% fixed position. There is some play in it. So... the cage can end up misaligned by a small amount, yet the screws will still fit. I know this first hand... because I went through a MULTI-DAY arduous effort to do this conversion, then when putting in the A/C climate control unit, I noticed a slight gap on one side. I then put in the supplementary switches and... slightly slanted. Yep, confirmed. the f*** cage is out of alignment. Thankfully I hadn't assembled the glove box yet, so I removed CC & switches, loosened screws, then finagled it. Wasn't easy, but I got it to like 99% aligned. This is something that should have been stressed in the DIY.
- Guard against screw loss. Holes, gaps, & crevices abound as you remove the transmission shift plate & ashtray module parts. These are "black holes" for any screws you might drop. It makes good sense to lay down a thin sufficiently long cloth/rag/towel over those crevices and/or tape up holes. As I was working on this, I was distracted for a moment, and when going for seating a screw that I wasn't accessible enough for 2 fingers, I used my screwdriver that required an attachment defeating the magnetic feature. I slipped... and the screw plummeted down into the bowels of the car, irretrievable.Thankfully I had an extra screw.
#38
I have removed and replaced my radio in my 2008 A4 and now the temp control unit will not power up , i have checked all the fuses and purchased a new temp control unit and ,,still wont power up ,please can someone help its hot here in Florida with no air
stevo_devo
08-14-2003 12:29 PM
