Audi A3 / S3 / RS 3 Discussion forum for the 8L and 8P Audi A3 S3 and RS3
Remove front license plate panel/filler plate?
Old 03-12-2012, 08:45 PM
  #11
EurosportAMG's Avatar
underneath the filler it's not clean, it's euro style plate spot.
and btw the filler is held by couple screws that you see them looking up and rest clips. easy diy
Old 03-13-2012, 02:13 AM
  #12
ben721364's Avatar
Thank you EurosportAMG. Where are the screws that you mentioned (on a 2012A3)? Aare they behind the grill?
Old 03-18-2012, 10:42 PM
  #13
Dj Toobs's Avatar
i have a 2011. As i recalled, for the filler there are no screws, just clips. I carefully yanked it out clip by clip, without any of them breaking off. Its to replace the rings that i had to open the top of the grill to unclip the audi rings. Here the result:
Old 03-19-2012, 03:54 AM
  #14
MikeSS's Avatar
What exactly did you do to change your rings? I found 3 bolts at the top but when I removed them it didn't appear that the grill was very loose. I, too, have a set of black rings I'd like to install but it looked like I needed to pull the entire bumper cover.
Old 03-19-2012, 10:47 AM
  #15
ben721364's Avatar
Thanks. Sounds good to me. Before I start yanking on it, I think I will stop by a dealership and take a look at the parts fiche. <BBG>
Old 03-19-2012, 12:09 PM
  #16
aTOMic's Avatar
Default 2011 A3:
From www.jimellisaudiparts.com
Order from the forum sponsor http://www.audiusaparts.com/(which also has a site like that) and is much cheaper.
-Tom
Old 03-19-2012, 12:55 PM
  #17
ben721364's Avatar
Thank you very much. It does indeed appear to be snapped in place! I just sent a note to AudiUSAParts.com. Thanks also for the referral.QUOTE=aTOMic*;24277091]
-Tom[/QUOTE]
Old 03-22-2012, 09:20 AM
  #18
Dj Toobs's Avatar
Besides the screws, i believe their are also clips that hold down the grill, on top that also need to be removed. Then carefully you pull the grill outwards just enough to stick your and in there and unclip the rings.
Old 03-26-2012, 08:34 PM
  #19
JaseZilla's Avatar
Thanks Ben for posting that diagram! That can be helpful!! Im looking to get a filler plate here soon
Old 03-28-2012, 10:46 AM
  #20
ben721364's Avatar
It wasn't me but I too appreciate the diagram.
Ben
Quick Reply: Remove front license plate panel/filler plate?
