Last edit by: IB Advertising
- Audi How to Clean Steering Wheel and Seats<br>Step by step instructions for do-it-yourself repairs.
Steering wheel / Power Steering question
Hi all,
I have a question about power steering system of 2006 Audi A3.
I noticed that when I have parked the car on totally flat surface, put it on Park and switch off the engine, the steering wheel turns very slightly left by itself, like going to its "normal" position or something... When I start the engine then, the steering wheel goes back to the position it was before I switch the engine off (turns a little right by itself). During that test, I have not pressed the brakes or touched anything except the ignition key...
Do you think I should check the steering angle assistant sensor for alignment with the VAG-COM and most importantly how do I find what kind is my sensor? Also where can I find more technical information about the power steering system? I just want to go to the mechanic prepared. I know I need to change a front right bearing, but it should not affect this situation...
Thank you in advance!
I don't know a lot about the power steering system, except that it's a servotronic steering assist and it cost me a small fortune to replace about 5 months ago. i would run a scan, couldn't hurt but im thinking the slight adjustment of the steering wheel when you turn it off may be from the power being cut and everything coming to rest as the system shuts down. is this something that just recently started or has it always occurred since you've owned the vehicle?
mrprism133
09-07-2015 07:22 PM
akitamike
09-05-2015 03:01 PM
Audi A6 2012 A6 3.0T Prestige (Atlanta)
QuickChange
09-04-2015 06:51 PM
Audi A4 2000 A4 Quattro ATW
ldorris
08-27-2015 10:25 PM
