Audi A3 / S3 / RS 3 Discussion forum for the 8L and 8P Audi A3 S3 and RS3
Old 08-09-2016, 11:44 AM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Audi A3 Tire Repair and Maintenance
Print Wikipost
tire pressure warning light reset
Old 04-24-2008, 01:03 PM
New Member
paulk571's Avatar
Default tire pressure warning light reset
My tire pressure warning light came on few days ago and it turns out I had a nail in one of my tire. That was great, the system worked. However, the warning light still comes on even after I fixed the tire.
Any idea on how to reset the warning light?
Thanks,
Paul
'08 A3 2.0T S-line / Titanium package
Old 04-24-2008, 05:25 PM
MikeSS's Avatar
Push the "SET" button??
Old 09-30-2013, 03:52 PM
Gath16's Avatar
Where is the reset button. I have no manual and have tired all the switches I could find. I have an 2008 A3 sline.
Old 10-01-2013, 02:52 AM
MikeSS's Avatar
U.S. 2008 A3s have the active TPMS system with sensors in the wheels. You have to put enough air in the tire for the sensor to report OK tire pressure. AFAIK there isn't a reset switch.
The OP has a car with the passive TPMS which uses the ABS to detect low pressure. These have a reset switch or dashboard function to reset.
Old 10-21-2013, 08:21 AM
Texmex13's Avatar
i am told you have to go thru the MMI to reset the low tire pressue warning light
Old 11-02-2013, 06:33 AM
iamaudihere's Avatar
Thanks,
Paul
Once you have the tire pressure back to normal, press an hold the set button for about 5 seconds.
the set button is located below the radio next to the hazard light.
Old 03-03-2016, 05:34 PM
Caljake's Avatar
Default Yes
This is correct, thank you for the tip!
buickfunnycar
17
10-01-2018 06:22 PM
gg948794478
A4 (B9 Platform) Discussion
02-23-2018 02:37 PM
EOhan
A4 (B7 Platform) Discussion
08-06-2017 08:18 PM
Q5 TDI
Audi A3 / S3 / RS 3
08-25-2014 04:56 AM
mikey1299
10-16-2008 05:17 AM
Quick Reply: tire pressure warning light reset
