09S5 Spark plug change
Good morning well I just recently changed out spark plugs. Parts wasfrom FCP EURO.
Overall it was easy.
A few things:
Coolant tank was flexible once you removed the 2 screws andraise it up out of the grommet at the bottom of the tank
Make sure you got the right tools for the job Ill post mytools PICS (also you may need 2-3 zip ties came in handy in tight spot pullingup the coil pack.)
I would say the passenger side air box was challenging dueto all the plastic very easy to crack the air box . There also 2 AC lines youhave to loosen up and move to the side with a little pressure not going tobreak.
Connection to coil l pack was tight. (Push tab down and usea screw driver to pry off)
A few pics
Total time was 1 hour and 45 mins.
A few things:
A few pics
Thanks
More pics
Yes first time changing plugs.
50k miles on the car
Local Audi dealership recommended & 55k miles and they wanted $ 862.00 out the door lol...
Any more question let me know its really easy if you not in a rush
Side question.
Why is your coolant green?
I thought all modern Audi coolant was pink/purple?
Was it swapped out for something else?
2 months ago I had to replace the radiator due to a crack at the bottom of the tank. Took it to a local European shop called Euro Fix and they replaced everything with a 3 year warranty.
I'm not sure of the different type of coolant for the Audi this being my first S5.
Here the place that repaired the car.
4266 Kenilwood Drive
Nashville, TN 37204
P: 615.724.4131
F: 615.724.4130
Hope this helps.
Nashville, TN 37204
P: 615.724.4131
F: 615.724.4130
Hope this helps.
Warranty
Here my warranty company
FYI
FYI
Hope this helps.
Hope this helps.
Audi Antifreeze - Audi G13 G12 Antifreeze - Pink Purple Audi Antifreeze
