Audi A5 / S5 / RS5 Coupe & Cabrio (B8) Discussion forum for the B8 Audi A5, S5 and RS5 Coupe and Cabriolet Model years 2009 - 2017
2013 A5 Cabriolet Questions
Old 09-13-2013, 05:55 PM
  #11
garlandpr's Avatar
Originally Posted by garlandpr
Maybe I need to copy the code and paste it in lower box for the new code and hit do it?
not sure...
used the X
Old 09-13-2013, 05:59 PM
  #12
Chocoholic_too's Avatar
Well i'm pretty sure that's all I did, went to the code hit backspace and typed in the new code, then exit and do it.
Then I went back to check if the code had changed and it had. Before the coding was 01000000. My S5 cab is also a 2013.
Old 09-13-2013, 06:00 PM
  #13
Maybe try it again with the "Exit" ......
Old 09-13-2013, 06:01 PM
  #14
garlandpr's Avatar
yes my code is exactly like yours.
Maybe I will try again tomorrow.
But thank you very much for your help
Old 09-14-2013, 05:38 AM
  #15
JGA5Cab's Avatar
Since you have the tools, you can enable the voice command feature that is shut off on the Cabriolets. There are several threads about it but I am not sure if the 2013/2014 version is the same fix.
Old 09-14-2013, 05:51 AM
  #16
Yes that's the main reason why I got the cable and it's very straight forward to do it. Just checking a box instead of manually changing code.
Old 09-14-2013, 06:28 AM
  #17
JGA5Cab's Avatar
I have read stuff about being able to cancel the DRL going out while working the turn signal. I guess that bothers some people.
I've had two people tell me that my DRL was malfunctioning not understanding that it goes out with the turn signal.
Old 09-14-2013, 07:06 AM
  #18
Yes , that annoyed me too. I coded that as well:
Keep LED DRL's on With Turn Signals
[09 – Cent. Elect.]
[Coding - 07] -> [Long Coding Helper] -> Byte 3 Bit 7 - Change 1 to 0
And I did this one too:
Fog Light turns on with turn signal (Curb Side Lighting)**
[09 – Cent. Elect.]
[Coding - 07] -> [Long Coding Helper] -> Byte 4 Bit 0 - Change 0 to 1
*Headlights must be on without Fog Lights for this to work.
Old 09-14-2013, 07:29 AM
  #19
JGA5Cab's Avatar
[09 – Cent. Elect.]
[09 – Cent. Elect.]
I was given the name of a local guy that works on VW/Audi products. He has the equipment. I will get in touch with him. The top feature is so awesome. I'd love to have that.
Old 09-14-2013, 08:53 AM
  #20
Quick Reply: 2013 A5 Cabriolet Questions
