Audi A5 / S5 / RS5 Coupe & Cabrio (B8) Discussion forum for the B8 Audi A5, S5 and RS5 Coupe and Cabriolet Model years 2009 - 2017
A5 2014 Warning "ECP" + orange Engine flashing
Old 08-25-2014, 05:21 AM
tr3ndsetr's Avatar
Default A5 2014 Warning "ECP" + orange Engine flashing
Re: 2014 Audi A5 2.0 AWD with 9700 Miles
Last night while driving home 4am, orange warning light "ECP" came on. I could feel my car sort of jerking as I accelerated. I managed to drive 30 miles home, but as I got close to home, I could smell gasoline, and a lot of fumes coming from the exhaust. The last thing i did was a gas fill up, but I securely closed gas cap.
Today I connected VAG COM. this is what the printout looks like...
Part seem to indicate Ignition coil, i think ????
" Part No SW: 8K5 907 115 J HW: 8K2 907 115 L "
Has this happened to anyone else with A5 yet?
Does anyone know if this is covered under warranty?
I found this video on Youtube to replace ignition coils
Googled the parts, looks like a $50 fix.
Can anyone please confirm, or let me know if they see anything else on VAG Printout. Thanks.
Sunday,24,August,2014,14:33:22:04118
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 12.12.2.0
Data version: 20140212
VIN: WAULXXXXXXXXXXXX License Plate: XXXXXXX
Mileage: 15670km-9736mi Repair Order: Repair1
Chassis Type: FH (8R0)
Scan: 01 02 03 05 06 08 09 15 16 17 19 26 36 42 44 46 52 53 56 5F
62 6C 72
VIN: WAULXXXXXXXXXX Mileage: 15670km/9736miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
06-Seat Mem. Pass -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
26-Auto Roof -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
56-Radio -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
6C-Back-up Cam. -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine (DET-CPMB) Labels: 06H-907-115-CDN.clb
Component: 2.0l R4/4V TF H09 0002
Revision: ECH09---
Coding: 622A0013242600062000
Shop #: WSC 29698 001 1048576
ASAM Dataset: EV_ECM20TFS0118K5907115J 001003
ROD: EV_ECM20TFS0118K5907115J.rod
VCID: 3979DC81B84984D69C9-806C
8 Faults Found:
10426 - Fuel Pressure too Low during Cold Start
P053F 00 [101] - -
Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 15679 km
Date: 2014.08.24
Time: 13:32:55
2838 - Fuel Rail/System Pressure
P0087 00 [175] - Too Low
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 15625 km
Date: 2014.08.24
Time: 02:27:59
4601 - Cold Start Idle Air Control System
P050A 00 [101] - Malfunction
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 15679 km
Date: 2014.08.24
Time: 13:33:08
10203 - Random/Multiple Cylinder Misfire Detected
P0300 00 [175] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 15625 km
Date: 2014.08.24
Time: 02:27:54
10591 - Cylinder 1
P0301 00 [101] - Misfire Detected
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 15679 km
Date: 2014.08.24
Time: 13:33:00
10593 - Cylinder 3
P0303 00 [175] - Misfire Detected
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 15625 km
Date: 2014.08.24
Time: 02:27:54
10594 - Cylinder 4
P0304 00 [237] - Misfire Detected
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 15679 km
Date: 2014.08.24
Time: 13:32:53
10205 - Cylinder Disabling
P130A 00 [040] - -
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Mileage: 15625 km
Date: 2014.08.24
Time: 02:27:57
Readiness: 0000 0000
Old 08-25-2014, 07:54 AM
jyges's Avatar
Default warranty? Isn't car still in warranty period?
why mess around yourself?
Old 08-25-2014, 07:59 AM
19hole's Avatar
Take a trip to your dealer and make use of the warranty. No need to try to fix this yourself and spend more of your time and money when Audi will fix it for free....
Old 08-28-2023, 09:15 PM
BGehl's Avatar
Default P053F code with rough start up
I was wondering what the fix was for this repair? I have a 2015 Audi A4 and I have the exact same codes right now that keep coming back especially P053F. Runs great except when you first start it up in the morning or after work.. I replaced the HPFP a year ago due to no start intermittently. Now I am having rough start up issue. I tried a new in tank fuel pump and fuel line pressure sensors already. I pulled the timing cover and checked the measurement between the two timing marks and I was at 126.4 mm. I only have an OBD 2 scanner so any help,would be appreciated.
kevin880
A6 (C7 Platform) Discussion
33
04-02-2014 06:50 AM
T0M3K
30v V6 Discussion
07-11-2007 05:02 PM
asisin
10-21-2002 12:26 PM
Crispy
08-03-2001 10:53 AM
Quick Reply: A5 2014 Warning "ECP" + orange Engine flashing
