Audi S5 2010 Engine intake filter replacement problem
Has anyone had trouble replacing the inlet filter? It seems to me that when the O-ring in installed I can't put everything back together. And without the O-ring it goes together. Any ideas ?
The air filter should have come with a very small lube tub for the O-ring. If not you can use motor oil or any type of lube so it slides in smooth. Hope this helps.
It did come with a lube but it do sent want to go in. I even tried the old o-ring and doesn't go back in.
Svart
A4 (B7 Platform) Discussion
09-28-2006 08:58 AM
Oettinger_A4
02-29-2004 07:47 PM
