first VAG scan...some questions
A brief synopsis of the situation. My battery failed the "test" at an Audi dealership. I took it there to have a used car inspection done after I recently bought it. The car dealership I purchased it at replaced the battery and then this fault code comes up when I have a friend run a scan for me. what do these codes mean please? Upon looking at a couple of forum discussions hear I see it could be an issue with the a/c temp controls, or something along those lines. My a/c is very hot when I first turn it on but then it cools really well after a couple of minutes. Also noticed a loud sound when it is turned on from engine bay, nothing alarming, but it is just noticeable. I assume this is regular or maybe not. I came from a 2015 Acura TLX , so I understand that this is a 2010 Audi S5,and maybe some things I hear now than with my 2.4l Acura. For the battery coding I am thinking maybe they did not program it to the car? any advice would be helpful, thanks.
Address 08: Auto HVAC (J255) Labels:Redir Fail!
Part No SW: 8T1 820 043 AQ HW: 8T1820 043 AQ
Component: KLIMA 3 ZONEN H08 0171
Revision: C1000000 Serial number:01211020091030
Coding: 48122000
Shop #: WSC 06325 000 00000
VCID: 000FAA74939F223E7E-8054
1 Fault Found:
01206 - Signal for Duration of Ignition Off Time
008 - ImplausibleSignal - Intermittent
FreezeFrame:
Fault Status: 00101000
Fault Priority: 7
Fault Frequency: 1
Reset counter: 9
Mileage: 103304 km
Time Indication: 0
Date: 2009.06.26
Time: 00:14:38
Address 01: Engine (J623-CAUB) Labels:079-907-560-CAU.clb
Part No SW: 8T0 907 560 T HW: 8T0907 560
Component: 4.2l V8/4V H12 0005
Revision: 76H12---
Coding: 01140009190F0120
Shop #: WSC 49467 000 1048576
VCID: 4B954D58EA593166DB-801E
1 Fault Found:
005634 - Power Supply Terminal 30
P1602- 002 - Voltage too Low - Intermittent
FreezeFrame:
Fault Status: 00100010
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 0 km
Time Indication: 0
FreezeFrame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: -40.0°C
Absolute Pres.: 0.0 mbar
Voltage: 0.000 V
Readiness: 0000 0000
Coding: 48122000
1 Fault Found:
FreezeFrame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 9
Mileage: 103304 km
Time Indication: 0
Date: 2009.06.26
Time: 00:14:38
Revision: 76H12---
1 Fault Found:
FreezeFrame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 0 km
Time Indication: 0
FreezeFrame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Voltage: 0.000 V
