Audi A5 / S5 / RS5 Coupe & Cabrio (B8) Discussion forum for the B8 Audi A5, S5 and RS5 Coupe and Cabriolet Model years 2009 - 2017
Way to prevent Carbon Build up
Old 08-13-2014, 11:28 AM
2014Q5TDI's Avatar
Default Way to prevent Carbon Build up
I had a 2011 335d BMW and it had a terrible issue with Carbon build up. I recently learned about BG products. I understand that dealers use this to prevent carbon build up and I was wondering if anyone has an experience with these products?
BG 44K, EPR (109), MOA.
BG 44K® Fuel System Cleaner | BG Products, Inc.
BG MOA® | BG Products, Inc.
BG EPR?: The best engine repair product is a maintenance product | BG Products, Inc.
I am thinking about using this with my new 2014 A5 Cab.
Old 08-13-2014, 01:35 PM
Brozee's Avatar
Out of any fuel products, BG is consistently high rated. Although this isn't the end all solution, some like it some don't. It's like arguing fuel additives... More of a placebo effect if you ask me. I use a bottle of techron in the gas tank every so often (every 5-10k or so).
Old 08-14-2014, 07:33 AM
AudiWorld Expert
Reggie's Avatar
The RS4 was the first major production car with direct injection and suffered from carbon buildup more than most other Audi vehicles. From the past seven years I have been following the attempts to prevent it on those cars - from catch cans to chemical cleanings etc. No one has found a good way to prevent it (other than having the engined designed to also have a injector in the manifold).
I kind of look at it as having a timing belt that needs to be changed - mechanical cleaning seems to be the only way to take care of this issue.
That said - BG makes the best products for our vehicles and I know the BG44K on the non direct injection vehicles did a great job on cleaning the fuel systems.
Edit: As opposed to the advice given on the following post - all my trips are short ones - the engine never gets warmed up. I have 33K so far and no check engine light. I am resigned to get a carbon clean in the next year though.
Old 08-14-2014, 10:42 AM
superswiss's Avatar
Received 1,065 Likes on 740 Posts
Honestly, the best you can do is to avoid frequent short trips where the engine doesn't reach operating temperature and to frequently redline to get the engine real hot to burn the crap off and blow it through. Having said that, I did have a cold start misfire on cylinder 6 at around 16,000 miles and the dealer peeked into the engine and saw minor carbon buildup on that cylinder. Audi told them to drop two cans of BG44K into the tank and instruct me to drive the car hard for 50 miles, so I did. Haven't had a misfire for the past 5000 miles.
Old 08-19-2014, 10:20 AM
mhblaw's Avatar
FWIW, I have a '13 RS 5 with 28K on it and no issues that I can detect with how it runs...great!
edle
A4 (B9 Platform) Discussion
74
04-22-2022 11:46 AM
LR95S97
10-20-2015 10:27 AM
truwarrior22
Q5/SQ5 MKI (8R) Discussion
08-10-2015 05:28 AM
dans93audi90s
10
09-25-2007 05:50 AM
®ob
Performance and Tuning
01-16-2004 02:42 PM
Quick Reply: Way to prevent Carbon Build up
