Key Fob Remote Functionality..
Hi! Does everyone know if our key fobs remotes have extra functionality other than lock, unlock, trunk and panic? Factory setting, without mods. I could've sworn my old Audi had remote window/sunroof closing function but I can't figure it out and I can't seem to find anything online.
Check out this app for your phone. Carista OBD2 - Vehicle Diagnostics and Customization | brew your own car. I bought the app and a OBDII port reader off amazon. Was able to do some basic modifications, including open/close windows and sunroof
Let me know how you make out. I just bought a 2010 A5 P+ and miss not having the window and sunroof functionality with the remote that my 2001.5 Passat had.
Once the feature is engaged by Vag-Com or that other OBD app, a menu option will appear in the MMI car menu allowing you to activate the window roll up operation.
So the functionality already exists and can be enabled with a Vag-Com? Likely my independent garage can do this if so. Good to know...thanks.
Yes, it's one of the most common Vag-Com mods and one of many that can be done with the Ross-Tech VCDS (Vag-Com) cable and software. Many of the AudiWorld members have invested in their own cable to identify issues and make modifications to their Audis (and VWs).
As far as functionality, it does everything it says it does. Reads/clears fault codes and then the modifications you see on that link. I can now open/close windows/sunroof with my keyfob, LEDs no longer turn off with blinker, and a few other things. They also send out periodic updates with more functionality. I think its definitely worth the price. And no, none of the mods will void your warranty. However, if you bring your car in for service/warranty work, they may clear the changes you made using the app depending on what they are doing.
Cool, thanks. I just tried it. Works well so far.. Do you know where I can get more info on some of the functionality? Is there like some kind of FAQ or ReadMe? For example: It has a "hidden menu" by pressing "Car + Setup". Where is setup in my console?? Or when the seatbelt option is US/Canada or Euro 1, 2, or 3.. It doesn't have a definition on what the three Euro options are. Those are just some of the examples I ran into. Any ideas?
