Audi A5 / S5 / RS5 Coupe & Cabrio (B8) Discussion forum for the B8 Audi A5, S5 and RS5 Coupe and Cabriolet Model years 2009 - 2017
stupid headlight sprayer messes up my hood - can it be disabled?
Old 02-08-2009, 09:06 AM
nicknyc's Avatar
Default stupid headlight sprayer messes up my hood - can it be disabled?
Every time I go to clean my windshield, the headlight nozzle sprays all over the hood and then leaks up the side of the hood/fender when I drive.
Is there any way to have this disabled either physically or programmatically (VAGCOM)? I avoid cleaning my windshield so I don't get junk all over my clean hood - not a good tradeoff
Old 02-08-2009, 09:21 AM
GLI_Man's Avatar
Default Disconnect, plug the water hose.
I found this out in reverse - my headlight washers weren't working.
Old 02-08-2009, 09:34 AM
nicknyc's Avatar
that's what I was going to ask the dealership to do at next checkup
Old 02-08-2009, 10:01 AM
AudiWorld Expert
Reggie's Avatar
On my cars it only comes on when the headlights are on
Old 02-08-2009, 11:35 AM
uberlinkA5's Avatar
Default Yes, turn your headlights off when you wash.
Not perfect, I know, but it helps. I have the same gripe, albeit minor.
Old 02-08-2009, 04:37 PM
AudiWorld Uber User
April's Avatar
Default I was just thinking that, and saw the reply :) Home brew washer fluid recipe below mimics
the original Audi stuff :
Typical washer fluid is about 2/3 water, 1/3 methanol. The yellow Audi stuff is 49% isopropyl alcohol, 16% methanol, and 35% water. So, both are basically alchohol and water, but the Audi stuff replaces most of the methanol with isopropyl alcohol. The blue stuff can foam, bubble and collect around the wiper blades and I've heard it's harder on the paint/plastics/wax. It can collect and clog the headlight washers in extreme cold. The Audi stuff is less likely to foam or otherwise obstruct vision - especially at speed.
Here's a home brew formula:
To make 1 liter of the original fluid you'll need to mix the following:
488 ml Isopropyl Alcohol*
162 ml Methanol*
350 ml Water
It's a concentrate, and you mix it with water according to what
freezing temperature you're willing to put up with.
Mixing it 1:2 with water gets you protection to +2 F.
*use "pure" components. Rubbing alcohol available at your pharmacy is roughtly 20% isopropyl. Chemical supply houses should be able to get you 99.9% pure substances. Isopropyl alcohol is much more hydrophylic and causes water to freeze at a lower temperature than methanol.
A quick and easy alternative is to get half a liter of typical washer fluid and mix with half a liter of Isopropyl Alcohol to get close to the Audi yellow stuff. It's not exact, but pretty close.
cletus141
05-16-2007 12:21 PM
A4b6
08-29-2004 11:51 AM
ArchAudi
12-15-2000 09:12 AM
Camosun
03-11-2000 11:16 AM
Quick Reply: stupid headlight sprayer messes up my hood - can it be disabled?
