Audi A5 / S5 / RS5 Coupe & Cabrio (B8) Discussion forum for the B8 Audi A5, S5 and RS5 Coupe and Cabriolet Model years 2009 - 2017
rust on wheel drums
Old 05-18-2010, 10:14 PM
  #11
Imola Ghost's Avatar
It's very common on just about every car out there. What you can do it pull your wheels off and paint them with some high temp paint. PROBLEM SOLVED!
Old 05-19-2010, 04:32 PM
  #12
ChipB's Avatar
Hello Bowline:
A picture is worth a thousand words....
Here is a photo of the the wheel on my S5. Note the three areas called out. I removed the hub cap so you can see the center of the wheel hub. It is very common to see a bit of rust on the disc rotor, in the area between the aluminum mounting flange and the cast iron of the rotor (the rotor "hat"), and on the center of the wheel hub.
So - do any of these correspond with the rust you are seeing? If so, this is perfectly normal - don't worry about it! And by all means do NOT think about applying any high temperature paint to these areas!
Old 05-19-2010, 06:35 PM
  #13
There is ABSOLUTELY nothing wrong with adding high temperature paint to the rotor hat, which is what I spoke of earlier.
Old 05-19-2010, 10:47 PM
  #14
bowline's Avatar
Thanks for the picture and correct terms. it is the rotor hat where I am experiencing the rust.
Old 05-20-2010, 06:54 AM
  #15
Banned
spaniardone's Avatar
My rotor hats are also a little rusted out, no big deal, is a raw material, any changes in weather, rain, etc applies.
Habber
03-09-2009 06:36 AM
heybiff
Audi 100 / A6 (C4 Platform)
01-05-2008 11:01 PM
acitrano
12-10-2004 09:32 PM
mikura
09-30-2004 04:53 AM
Russ Burns
59
02-03-2000 06:51 AM
Quick Reply: rust on wheel drums
