S5 error codes
S5 error codes
Hi guys
Got the car yesterday after full respray and got the below codes.
I also changed shocks and springs to the car
Tried to clear them with VCDS but they still coming up.
Any ideas?
Sunday,14,February,2016,16:54:34:14675
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 15.7.3.0
Data version: 20151216
Ross-Tech: Home
VIN: WAUZZZ8T08A036984 License Plate:
Mileage: 98840km-61416mi Repair Order:
Chassis Type: 8T (8T0)
Scan: 01 03 05 06 07 08 09 0E 10 15 16 17 19 1E 36 37 42 46 47 52
53 55 56 77
VIN: WAUZZZ8T08A036984 Mileage: 98840km-61416miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
06-Seat Mem. Pass -- Status: OK 0000
07-Control Head -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
0E-Media Player 1 -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
1E-Media Player 2 -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
37-Navigation -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (J623-CAUB) Labels: None
Part No SW: 8T0 907 560 EM HW: 8T0 907 560
Component: V.7 JHM H10 0003
Revision: 76H10---
Coding: 01140003180F0120
Shop #: WSC 06325 000 00000
VCID: 0919A994A000117626-805C
6 Faults Found:
005489 - Left Engine Mount Solenoid Valve (N144)
P1571 - 001 - Short to Plus
Freeze Frame:
Fault Status: 01100001
Fault Priority: 2
Fault Frequency: 2
Reset counter: 255
Mileage: 98733 km
Time Indication: 0
Date: 2016.01.25
Time: 14:32:22
Freeze Frame:
RPM: 607 /min
Load: 29.4 %
Speed: 0.0 km/h
Temperature: 93.0∞C
Temperature: 57.0∞C
Absolute Pres.: 1000.0 mbar
Voltage: 13.716 V
005715 - Please check DTC Memory of ABS Controller
P1653 - 001 - - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 98739 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 30.0∞C
Temperature: 30.0∞C
Voltage: 11.176 V
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 98739 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 30.0∞C
Temperature: 30.0∞C
Voltage: 11.176 V
P1653 - 008 - - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 98739 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 30.0∞C
Temperature: 30.0∞C
Voltage: 11.176 V
049472 - Body Control Module (Central Electric)
U0140 - 008 - No Communications - Intermittent
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 255
Mileage: 98740 km
Time Indication: 0
Date: 2016.02.05
Time: 11:44:54
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 28.0∞C
Temperature: 29.0∞C
Absolute Pres.: 1010.0 mbar
Voltage: 9.017 V
049508 - No Communications with HVAC Control Module (J301)
U0164 - 008 - - Intermittent
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 98836 km
Time Indication: 0
Date: 2016.02.14
Time: 12:46:06
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 48.0∞C
Temperature: 45.0∞C
Voltage: 11.049 V
Readiness: 0100 0000
Any ideas?
Ross-Tech: Home
53 55 56 77
Revision: 76H10---
6 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 255
Mileage: 98733 km
Time Indication: 0
Date: 2016.01.25
Time: 14:32:22
Freeze Frame:
RPM: 607 /min
Load: 29.4 %
Speed: 0.0 km/h
Temperature: 93.0∞C
Temperature: 57.0∞C
Voltage: 13.716 V
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 98739 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 30.0∞C
Temperature: 30.0∞C
Voltage: 11.176 V
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 98739 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 30.0∞C
Temperature: 30.0∞C
Voltage: 11.176 V
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 98739 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 30.0∞C
Temperature: 30.0∞C
Voltage: 11.176 V
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 255
Mileage: 98740 km
Time Indication: 0
Date: 2016.02.05
Time: 11:44:54
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 28.0∞C
Temperature: 29.0∞C
Voltage: 9.017 V
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 98836 km
Time Indication: 0
Date: 2016.02.14
Time: 12:46:06
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 48.0∞C
Temperature: 45.0∞C
Voltage: 11.049 V
