Audi A5 / S5 / RS5 Coupe & Cabrio (B8) Discussion forum for the B8 Audi A5, S5 and RS5 Coupe and Cabriolet Model years 2009 - 2017
S5 Instrument cluster is BLANK
Old 10-17-2016, 08:06 AM
Oenophile's Avatar
Default S5 Instrument cluster is BLANK
Blank instrument cluster...any of you have this issue? What might be the fix?
Thanks
Old 10-17-2016, 08:11 AM
19hole's Avatar
Other than the obvious bad fuse, I can't begin to think of what may cause that.
Old 10-18-2016, 07:21 AM
Former Vendor
Tanin Auto's Avatar
Thanks
Hi, Tanin Auto Electronix here. We are vendors on the site. We repair instrument clusters and also sell replacement parts like LCD screens.
What year is your S5?
Old 10-18-2016, 07:31 AM
Oenophile's Avatar
Its a 2012. And it is not a fuse. Wish it was!
Old 10-19-2016, 07:08 AM
Oenophile's Avatar
Dealer wants it for a day to do a "Reboot" to the system. The tech is thinking this may be enough to bring it back to life. If it needs replaced I'm guessing its a bit pricey?
Tanin Auto...what would be your thought/suggestion?
Old 10-19-2016, 01:47 PM
Former Vendor
Tanin Auto's Avatar
Ok, let's trouble shoot a bit. Don't mind the questions. I just don't want to assume from photo alone.
Is your vehicle able to start? is the center screen only black or the entire cluster? Do the gauges work or nothing works? What does work, and what doesn't work?
Old 10-20-2016, 06:01 AM
Oenophile's Avatar
Yes, it starts and runs and all else works as it normally would.
Everything works except the center (2'x4"ish) digital panel.
For a week or two this area went off and on then it then it went blank full time.
Yes, the top digital panel is still working.
I do get a loud beep ~30-40 seconds after starting and then moving the car.
Old 10-20-2016, 06:44 AM
the_duke's Avatar
VCDS codes?
Old 10-20-2016, 11:34 AM
Oenophile's Avatar
Not sure what VCDS codes are? What are you asking?
Old 10-20-2016, 11:57 AM
the_duke's Avatar
VCDS is diagnostic software for Volkswagen Auto Group cars. It's usually step 1 in diagnosing problems. I'm sure your dealer used the factory scan tool but i'd be curious to know what fault codes you have.
Quick Reply: S5 Instrument cluster is BLANK
