Audi A5 / S5 / RS5 Coupe & Cabrio (B8) Discussion forum for the B8 Audi A5, S5 and RS5 Coupe and Cabriolet Model years 2009 - 2017
RS5 keys
Old 04-01-2014, 09:59 AM
Ash83's Avatar
Default RS5 keys
when I check MMI car > service > registered keys : i get 3 keys registered.
I have 2 full keys + One plastic temp key, does that plastic key counts as the 3rd key that is registered to my car? or i need to take the car back to the dealer to let them disable it?
I bought this car new.
Old 04-01-2014, 11:36 AM
superswiss's Avatar
Received 1,065 Likes on 740 Posts
Of course the plastic key counts as the 3rd key. Did you think it was for decoration? It has a chip in it so it can start the car and therefore needs to be registered. The only thing it doesn't have is a transponder, so that's what this little key fob housing in your glove box is for. You put the plastic key in there and then slide it into the ignition slot to start the car.
Old 04-01-2014, 12:49 PM
Ash83's Avatar
i thought the plastic key is to unlock the car
Old 04-01-2014, 01:35 PM
superswiss's Avatar
It does that, too. You can unlock and start the car with it. The idea is that you keep it in your wallet, so that if you loose your main key you can still unlock, start and drive the car.
Old 04-02-2014, 11:14 AM
mikejaeggi's Avatar
dumb question about the smart key...why insert it in ignition slot when you can just keep in pocket and hit the push button start? why does Audi make that slot?
Old 04-02-2014, 11:37 AM
superswiss's Avatar
As I mentioned above, the plastic key doesn't have a wireless transponder. Keeping it in your pocket won't start the car. You have to put the plastic key in the case that's inside your glove box (looks like the plastic shell of the regular key fobs) and then insert it into the ignition slot and push it to start the car.
Also, the whole smart key is optional in most countries, so the slot is also there for when you don't have the smart key option.
Old 04-02-2014, 12:00 PM
Ash83's Avatar
can the plastic shell alone in the glove box start the car if it was inserted in the key slot? or it needs the plastics key to trigger something inside it to be able to start the car.
Old 04-02-2014, 12:10 PM
superswiss's Avatar
Nope, the plastic shell alone won't start the car. That would mean somebody could just break into your car and drive off with it. It needs the plastic key inside of it which contains the coded chip that will unlock the ignition.
patinsd
S4 (B8 Platform) Discussion
10
07-22-2010 09:38 AM
e314ds
08-24-2008 01:05 PM
Maini
07-13-2008 02:57 PM
greekzilla
11
10-27-2002 01:54 PM
AaronG79
04-12-2002 04:25 PM
Quick Reply: RS5 keys
