are these ok rotors for my 2010 3.2 a5?
are these rotors ok to buy for my 2010 a5?
im selling the car soon so i dont want to get crazy and spend a ton on nice stuff
steering wheel shaking while braking but ceramic pads still have 50% life left, do i need to replace them too?
Audi A4 A5 Quattro Q5 2008 2012 Set of 2 Front Disc Brake Rotors 320mm OD Brembo | eBay
I would just re-bed the pads before new rotors.
A more aggressive pad (aka, a race pad) will typically clean up a dirty rotor because of how abrasive it is at cold temperatures, but if you don't change your pads and you have some uneven build up on the rotors, then you might be stuck because the same pads (typically) won't clean up their own residue.
I have to confess I went through this last year. I already had wobble and needed to do my pads, so I said f**k it and replaced the rotors also. It wasn't much more work while I had the wheels off (and I'm an idiot who can afford to replace his rotors to get rid of wobble during braking).
If sloops suggestion doesn't pan out, just have them turned lightly at any brake shop to have the pad build-up removed and then do a proper bedding in process directly after.
Are you sure your steering wheel vibrations aren't also attributed (in a small way) to faulty front lower control arm issues? There's TSB's out on this.
-Warped- Brake Disc and Other Myths
BSK
01-17-2006 05:09 PM
in2audi
10-27-2004 05:24 AM
awloS4
08-18-2003 09:39 PM
coolnesh
08-07-2003 06:50 AM
A3 4 Me
04-01-2003 02:39 PM
