Bluetooth Problem - AudiWorld Forums
Audi A5 / S5 / RS5 Coupe & Cabrio (B8) Discussion forum for the B8 Audi A5, S5 and RS5 Coupe and Cabriolet Model years 2009 - 2017
Bluetooth Problem
Old 02-13-2011, 11:01 PM   #1
Default Bluetooth Problem
Hi, I bought my Audi A5 (premium plus with nav) about two months ago. I've been using the Bluetooth paired with my iphone 4 and today suddenly I started to hear noisy static noise through the speaker when I'm on the phone. I tried turning the bluetooth on and off both on my iphone and audi MMI but still same problem. The static noise is louder then other person's voice on the phone so I can't even clearly understand. Does this have to do with a bluetooth connection or the speaker? I can hear the music and nav voice clearly. Just the bluetooth. Whom should i contact for this problem?
Thanks in advance.
Chris
Jazzciel is offline   Reply With Quote
Old 02-14-2011, 05:46 AM   #2
Huey52's Avatar
If the music and Nav are fine then most likely it is the Bluetooth conectivity. Try re-initializing the Bluetooth from scratch as that can often remedy.
Huey52 is online now   Reply With Quote
Old 02-17-2011, 08:32 AM   #3
Quote:
Thanks in advance.
Chris
How do you reinitialize the bluetooth? I am having problems with my Q7, all of the sudden the phone will not connect, but the radio/cd pauses every 30 seconds like it is accepting a call... I cannot get any of the feature buttons to work. Is there a hard reset?
WoodenWords is offline   Reply With Quote
Old 02-17-2011, 08:38 PM   #4
what year is yor Q7? go to telephone>setup, and delete your paired bluetooth devices. Try to re-pair your phone.
What phone are you using?
IAS5 is offline   Reply With Quote
Old 02-20-2011, 12:44 PM   #5
m444's Avatar
There is a MMI software available update for some of the 2011 B8s. Check with your dealer.
m444 is offline   Reply With Quote
Old 03-10-2011, 09:41 AM   #6
After a couple of days, the issue got solved automatically. I tried restarting the Bluetooth connection several times I guess that helped. Thanks
Thread Thread Starter Forum Replies Last Post
Adding bluetooth audio to my new (to me) 2009 Cabriolet with Bose xkahn A4 Cabriolet (B6 Platform) Discussion 3 08-07-2016 06:38 PM
Modify 2016 Q5 AMI cable to stream music and sound through bluetooth dongle ltooz_a6_a8_q7 Q5/SQ5 MKI (8R) Discussion 12 11-29-2015 08:21 PM
Modify AMI cable to stream music and sound through bluetooth dongle ltooz_a6_a8_q7 A8 / S8 (D3 Platform) Discussion 13 11-29-2015 06:42 PM
ATTN D3 A8 Owners:OEM AMI Bluetooth Adapters Located! milellie111 A8 / S8 (D3 Platform) Discussion 18 09-19-2015 08:22 AM
2005 AR DVD navigation? cdu Audi allroad 0 09-05-2015 09:11 PM
Tags
2007, 2011, a1, a5, a6, a8, audi, bluetooth, connected, connecting, connection, convertible, iphone, problem, problens, static
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
What's your question?
Send
