clutch pedal sticking to the ground, transmission leaking?
Good day everyone, so earlier today, I was at a light. I had my foot on the clutch about to go and it was like the car stalled even though my foot was on the clutch. After that happened, the clutch pedal stayed all the way down. After settling with it and lifting the clutch pedal up with my foot, I could get it in gear and limped home. While at home and trying to figure out what was happening, after trying again, I couldn't get it into gear. The clutch pedal was even lighter and just went to the ground. I ended up noticing under my car fluid which I can only assume was either from the transmission or slave/master cylinder after looking at the forums but couldn't find a concrete answer on this. Anyone have any ideas?
Classic slave cyl failure symptoms. The fluid is brake fluid. Be aware that the leakage can drain the reservoir and get air into braking system rendering your brakes inoperable.
The good news is that these slave cylinders are external to the bell housing and providing your clutch is still good, will not require dropping the transmission. I just had to replace one on a TT and those are internal. Everything has to come apart for them. Good luck.
I'm relatively new to the German vehicles and haven't owned a manual one of these yet but I've never seen a hydraulic system shared like that before.
Immediately check your brake fluid level!!
If your brake fluid reservoir is low, fill it NOW. If it goes dry, you won't have brakes and you'll have air in the lines when you fill it up.
So we were putting in a new slave cylinder. We were bleeding the system. For a good bit the clutch peddle would still hit the floor until pressure came back but this was still early on. The pressure that came back kept the clutch peddle an inch or 2 from the fire wall and was firm there. The clutch peddle when pushed back would still fall back with little force to that position but with every pull back it was also getting pressure coming up. Now at this point I decided to push back as hard as I can and pop, it went back down and under the engine started leaking again. Im wondering if I just destroyed another slave cylinder and need a new one or if there is an under lying issue that the pressure plate could be screwed. Anyone got any ideas?
Any solution yet ?
did you find the solution ?
nobodeuno
13
11-29-2007 07:13 AM
snowchaser
08-04-2006 07:11 AM
Baileyw2
04-18-2006 05:37 AM
