Electrical Gremlins - Convenience Key
#11
Ow..electrical gremlins. Maybe time to replace car?
Getting back on topic. I think the mechanical locking mechanism in my driver's door may be toast. My fob will lock the mechanism on the passenger's door - I hear the "clunk" but I don't get the same for the driver's door. I might try that cycling on/off thing via the inside door locking switch to see if that shows any positive results. Failing that, I think maybe I have to replace the locking mechanism inside. Not really looking forward to removing the door panel. Past experience on other cars has shown that it's never 100% the same afterwards.
I've already replaced both door (touch) sensors last summer.
Sometimes I can improve the panel by using a better grade of plastic sheeting or even adding dynamat sound dampening.
Once this stuff starts to go you really have to consider how much aggro you want to put up with for the next couple years, not to mention the salvage value of the car if in a minor fender bender.
#12
Things like door mechanisms should last the life of the car. But I share your pain on removing door panels.
I think I read somewhere that there are teeth or something similar on the locking mechanism tubler and that a few of those teeth can break off which prevents a full lock through electronic means. It does lock using the physical key easy enough though. I just miss having the full functionality of my key fob.
Am I getting lazy/old? ...... don't answer that. lol
Ragdoll
10
08-16-2008 08:09 AM
marTTian01
08-06-2006 09:05 AM
CO AVANT
VAG-COM Discussion
06-25-2005 07:32 AM
