TPMS Error - AudiWorld Forums
Audi A5 / S5 / RS5 Coupe & Cabrio (B8) Discussion forum for the B8 Audi A5, S5 and RS5 Coupe and Cabriolet Model years 2009 - 2017
TPMS Error
Old 08-14-2009, 05:34 AM   #1
Default TPMS Error
I was driving on the Highway yesterday and the TPMS (Tire Pressure Monitoring sytem) error came up. After about two mins it turned off and has not come on since then. Has anyone else experienced this before in the past?
Xphstos is offline   Reply With Quote
Old 08-15-2009, 10:40 PM   #2
Eric - The Red S4's Avatar
This will happen from time to time. I've had it happen a number of times on my S4 over the years. Likely an interfering signal or something. I've also had it go off when travelling at high speeds for long periods of time.
Eric.
Eric - The Red S4 is offline   Reply With Quote
Old 08-16-2009, 05:42 AM   #3
How smart are the tire pressure sensors?
What I mean is that in the Audi if you rotate the driver's front tire to the back, will the sensor know that it has changed position? With my current car, you had to go to the dealer to rotate tires so they could reprogram the location of the tire to the computer.
zub3qin is offline   Reply With Quote
Old 08-16-2009, 10:19 AM   #4
You set the tire pressures to where you want them and then you reset the TPMS sensors in the MMI system. It then knows what each tire should be. You can do this any time you intentionally change tire pressures.
Hobbes is offline   Reply With Quote
Thread Thread Starter Forum Replies Last Post
LED (driving, low-beam) headlight conversion nZtiZia Q7 Discussion 3 12-04-2015 03:23 PM
2015 Q5 TDI 5,500 miles...Glow Plug light flashing.. SJGQ5 Q5/SQ5 MKI (8R) Discussion 4 10-01-2015 09:44 AM
OEM wheels to....>> CobraCommander A8 / S8 (D3 Platform) Discussion 11 09-30-2015 10:14 AM
Can anybody tell me what this error on my dash means? Able89 A6 / S6 (C5 Platform) Discussion 1 09-28-2015 06:35 PM
Error code P0610 Nathaniel411 Audi allroad 0 09-26-2015 12:30 PM
Tags
a3, a5, a8, audi, codes, error, errors, high, monitoring, pressure, q5, resetting, speeds, system, tire, tpms
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
What's your question?
Send
