01316 - ABS Control Module code
Old 06-05-2007, 03:03 PM
New Member
gofuyose's Avatar
Default 01316 - ABS Control Module code
This is actually my first post, and I noticed you guys needed all codes posted when you have a problem. Well, my buddy scanned my 03 Allroad, and he sent me this ... so this is all I have; hopefully this will work.
I have the suspension light, the ESP, and ABS light, and get the code "01316 - ABS Control Module." It then tells me to check the fault codes, but we found nothing wrong with the ABS on the scan for them ... what is going on?
ABS does not work, lights come on when you touch the brakes (and continue to stay on), but go out when you turn off the car, then start it up (almost like it's trying to reset itself every time?)
Thanks for any help.
Mike
Here is what he sent me:
Sunday,03,June,2007,14:38:55:52635
VAG-COM Version: Release 704.1
Address 01: Engine
Control Module Part Number: 4Z7 907 551 S
Component and/or Version: 2.7L V6/5VT G 0020
Software Coding: 07755
Work Shop Code: WSC 20209
Additional Info: WA1YD64B73N008930 AUZ7Z0B2158388
1 Fault Found:
17862 - Exhaust Gas Temp Sensor 1 (G235): Short to Ground
P1454 - 35-00 - -
Readiness: 0000 0000
Sunday,03,June,2007,14:59:49:52635
Address 34: Level Control
Control Module Part Number: 4Z7 907 553 E
Component and/or Version: - 2C1A1 D040
Software Coding: 25500
Work Shop Code: WSC 09999
1 Fault Found:
79-10 - Please Check Fault Codes - Intermittent
MetalMan
VAG-COM Discussion
06-09-2010 07:32 PM
pablo2001
07-11-2007 07:26 AM
modwad
VAG-COM Discussion
9
09-10-2006 09:33 PM
petkata
07-11-2003 04:49 PM
ScotD
07-01-2003 05:59 AM
Quick Reply: 01316 - ABS Control Module code
