01V Tiptronic Allroad vs A6
Manual 6 spd tranny for Allroad and A6/S4 are different.
What are the differences between the 01V (5HP19FLA) used in the Allroads (most are EYK) and A6 (most 2.7T are FAQ)?
Again, different final drive ratio (but internal gearing the same)?
If I wanted to swap an A6 tiptronic (FAQ) into an Allroad, what would need to changed? Just the center diff (at the end of the tranny)?
The gear ratios are different.
I learned this the hard way by flashing the wrong software 156DJ over 156A and it was shifting funny and got the codes below.
Once flashed back to original, all is well. Wether the difference is in valve body or the planetary/sun gears I do not know.
<code>
Control Module Part Number: 4B0 927 156 DJ
Component and/or Version: AG5 01V 2.7l5VT USA 1717
Software Coding: 00002
Work Shop Code: WSC 00000
2 Faults Found:
17118 - Gear 4: Incorrect Ratio
P0734 - 35-00 - -
P0734 - 35-00 - -
</code>
<code>
2 Faults Found:
P0734 - 35-00 - -
P0734 - 35-00 - -
</code>
Go to link below. It's a PDF you can find in many places. In the first couple of pages is has a list of all the 01V variants and their applications. Then scroll down to the individual parts listed to see those that are different. There are loads of different combinations. The differences could be an individual gearing component, clutch variations or valve body differences to name a few.
It depends on which A6 you sourced and which allroad its going into.
http://www.zf.com/media/media/docume...4/5HP19FLA.pdf
My AR is a 2001:
Audi Allroad Quattro Wagon V6 2.7L* 2001 – 2002 EYK 01V 300 050A 1060 040 053
My A6 is a 2003:
Audi A6 2.7T Quattro Sedan V6 2.7L* 2000 – 2003 FAQ 01V 300 049K 1060 040 063
5HP19FLA Technical Information
Torque, Gear Ratio & Weight
Input Torque 1st
Gear
nd
Gear
rd
Gear
th
Gear
th
Gear
Rev
Gear Drive Weight
(approximate)
310 Nm 3.57 2.20 1.51 1.00 0.80 4.10 AWD ~142 kg (312 lbs.)
My A6 is a 2003:
Input Torque 1st
Gear
nd
Gear
rd
Gear
th
Gear
th
Gear
Rev
Gear Drive Weight
(approximate)
From what I can see, the internal gearing components are identical for both transmissions. The output for the front wheels is also different. You would have to change these components as well as the centre diff.
AudiWestPR
02-22-2019 08:32 AM
Ochlockonee
10-07-2005 07:42 AM
adream
01-07-2001 09:12 AM
Scott
12-15-1999 10:06 AM
