Air suspension bypassing - AudiWorld Forums
Old 05-21-2014, 02:20 PM   #1
Default Air suspension bypassing
Hello I will apologize up front as I am new here and I'm dealing with my 1st Audi. I have a 01 Allroad and the most recent problem is the air compressor not running. I have power at the compressor and suspect it is locked up. My car has 172k miles and tired of sinking money into it.
Here is my question - Can I weld a bung into the air tank and install a schrader valve in order to be able to supply air to the suspension? I am looking to disable the ride control and just be drive the car in a level position.
These are the parts that have been replaced in the last 6 months:
Radiator
Front Air Bags
Front brakes
Front Axles
front ball joints
new tires
I am tired of spending money I am hoping for a quick fix and I plan on selling the car.
Thanks for any help in advance.
dfiremn is offline   Reply With Quote
Old 05-21-2014, 10:23 PM   #2
Default air suspension
The air suspension System is dynamic, all the time correcting the height., And height changes depending on the drive speed. The least expensive repair it: dismantles the compressor and check it. Whether the compressor is broken, buy a Used one for 100 $ (Or less) on Ebay
amiram is offline   Reply With Quote
Old 05-22-2014, 04:56 AM   #3
I Agree with amiram,
if you definetely have 12V at the compressor plug, then replace it,
NOTE: you should only get 12V with the ignition on, if 12v is constant with ignition off or on then the relay is stuck on hence the compressor burned out!!
too difficult to overrive and just "fill" the system from one place, this would only work with a valve on each corner to inflate each corner individualy
regards
Andy
bagpipingandy is offline   Reply With Quote
Old 05-22-2014, 05:23 AM   #4
silverd2's Avatar
Quote:
Please show us an example of a working used compressor on eBay for "100 $ (Or less)"....the compressor is well over $1000 new and the going rate is about $400 used on eBay.
I'd like to buy a $100 unit and resell it for triple that...which I could.
TIA...unless this is just all talk, AGAIN.
silverd2 is offline   Reply With Quote
Old 05-22-2014, 06:36 AM   #5
Default Air comp
<<<@!1!@>>>
I purchased my compressor six months ago for 50$+ 20$ shipping+ New piston ring (Item NO.181199306617). The compressor I bought is a Mercedes Benz, and should replace the main power connection That you are dismantling from your old compressor. Same with the compressor of a Land Rover, etc.
http://www.ebay.com/itm/175-Remanufactured-WABCO-Mercedes-Air-Suspension-Compressor-2113200304-/191054834219?pt=Motors_Car_Truck_Parts_Accessories&hash=item2c7bc16a2b&vxp=mtr
http://www.ebay.com/itm/00-06-MERCEDES-BENZ-W220-W215-S500-S430-S600-OEM-AIR-SUSPENSION-PUMP-COMPRESSOR-/181034582881?pt=Motors_Car_Truck_Parts_Accessories&hash=item2a26808361&vxp=mtr
http://www.ebay.com/itm/1998-2004-Land-Rover-Discovery-2-td5-suspension-air-compressor-/221439231197?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item338ece84dd
http://www.ebay.com/itm/Audi-Allroad-Air-Suspension-Compressor-Wabco-Pump-Repair-Kit-/151290130234?pt=Motors_Car_Truck_Parts_Accessories&hash=item2339982f3a&vxp=mtr
http://www.ebay.com/itm/AUDI-A6-C6-ALRROAD-Air-Suspension-COMPRESSOR-WABCO-OEM-Repair-Kit-/281221940050?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item417a224352
Attached are some options with a price slightly higher. On eBay you need fishing.
On the other hand, maybe fuse or relay is broken?
Old 05-22-2014, 09:42 AM   #6
Default External air pressure source
Radiator
Front Air Bags
Front brakes
Front Axles
front ball joints
new tires
You will be able to connect an external air source to the air pressure hose near air tank. You need a compressor with air drier and with pressure switch up to 120PSI. You must leave the old compressor in place That when the vehicle lowers level the pressure is released out through the compressor, Just disconnect the old compressor power supply And connect it to the external compressor.
Old 05-22-2014, 11:38 AM   #7
Default Ebay item
Audi 2001 allroad Air Sunspension Pump (181199306617)
Member ID vanjafashion | Feedback score of 80 | 100.0%
Sale date: 26/08/13
US $50.00
29.62
Free P&P
Sell this item
View seller's other items
More actions
Old 05-22-2014, 01:04 PM   #8
silverd2's Avatar
Sale date: 26/08/13
US $50.00
29.62
Free P&P
Sell this item
More actions
...still waiting. The OP "might" be looking for one for sale right now...not a bargain from a year ago.
Someone looking to save money, but willing to dig deeper (as the OP stated) would be pulling the present compressor to find the problem and let the car do the work of leveling it long enough to unload it ("sell it"...good advice).
Adding an outside source of air pressure is a terrible idea (would not sell the car)...expense and over-complication that does NOT address the problem causing the failure....wow.
The OP didn't specify when and exactly where he got 12V near or at the compressor.
Best case scenario, the motor or piston may not be jammed or burned out...the brushes could just be carboned up. I'd pull it, check compressing piston for movement, reassemble and put 12V to it while firmly tapping the motor casing, if not a complete disassemble to check brushes and bearing/bushing....trouble maybe, but no more $$ invested to assure the compressor is not salvageable for even a short time.
Old 05-23-2014, 07:03 PM   #9
I thank everyone for the info. After sitting for 2 days I started the car up today and the compressor ran, and leveled the car. I had to play with the ride height control buttons but I managed to get the car to the standard height. I cannot get it to manually go any higher but at least it is drivable at this point.
Thread Thread Starter Forum Replies Last Post
An ounce of Pinch Bolt prevention ohsigmachi A8 / S8 (D3 Platform) Discussion 4 03-29-2016 06:04 AM
A/C not working properly Junius A8 / S8 (D3 Platform) Discussion 33 02-19-2016 09:06 AM
Adaptive Air Suspension v/s Sport Adaptive Air Suspension Pmpsch Q7 MKII Discussion 14 12-06-2015 02:14 PM
New Owner Needs Help With New Tires!!! (2014 Audi Q7 3.0 TDI Prestige) DenverAudiQ7 Q7 Discussion 8 10-01-2015 08:38 PM
Air suspension on 2001 vs 2005 models mxp Audi allroad 6 09-24-2015 10:51 PM
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
What's your question?
Send
