allroad 2.7t power failure while driving
Old 07-22-2016, 06:36 PM
christiandflores@gmail.com's Avatar
Default allroad 2.7t power failure while driving
I was driving today through rancho santa fe, while accelerating out of a turn my engine cut out all of a sudden for no apparent reason right, fortunately i was able to get it off the road. i attempted to restart it through push starting and normal starting
does anyone have an idea of what might be wrong? Thanks
I've already ruled a bad key. The starter spins and the fuel pump works as well.
Ironically i was testing out a video microphone specifically for engine audio, so its all on video. Hopefully the audio from the footage can help.
https://www.youtube.com/watch?v=pmzB...ature=youtu.be
At the moment i get the codes below, i removed irrelevant codes.
Auto-Scan
Finished
Chassis Type:4B
Scan: 01 02 03 06 08 15 16 17 18 22 34 35 36 37 45 55 56 57 65 67
75 76 77
Address 01: Engine Labels: None
Part No SW: 4Z7 907 551 L
Component: 2.7l V6/5VT G 0001
Coding: 06712
Shop #: WSC 02325 000
VCID: 4CDBF7337B5D167F93FB468303-5184
Subsystem 1 - Part No SW: WA1-YD5-4B7-2N1
Component: 02024 AUZ7Z0B2037522
5 Faults Found:
17865 - Exhaust Gas Temp Sensor 2 (G236)
P1457 - 35-10 - Open or Short to Plus - Intermittent
17978 - Engine Start Blocked by Immobilizer
P1570 - 35-10 - - - Intermittent
17746 - Camshaft Position Sensor (G40)
P1338 - 35-00 - Open or Short to Plus
17800 - Camshaft Position Sensor Bank 2 (G163)
P1392 - 35-00 - Open Short to Plus
16486 - Mass Air Flow Sensor (G70)
P0102 - 35-00 - Signal too Low
Address 03: ABS Brakes Labels: None
Part No SW: 4Z7 907 389 A
Component: ABS/ESP allrad D5502
Coding: 06495
Shop #: WSC 00000 000
VCID: 4AD7F12B7129084FA1E7306B19-5184
1 Fault Found:
18265 - Load Signal
P1857 - 35-00 - Error Message from ECU
Address 34: Level Control Labels: None
Part No SW: 4Z7
Component: - 2C1A1 D040
Coding: 25500
Shop #: WSC 09999 000
VCID: C5CD4217D8376737CCB57B2FD8-5184
2 Faults Found:
01770 - Temperature Sensor for Level Control Pump/Compressor (G290)
30-10 - Open or Short to Plus - Intermittent
01316 - ABS Control Module
79-00 - Please Check Fault Codes
Old 07-22-2016, 07:50 PM
Banned
PaperToast's Avatar
id say your problem is the camshaft sensor and maf sensor
change those out and you should be good
Old 07-23-2016, 06:25 AM
MrKid's Avatar
Not to make you nervous, but did I hear a "clank" right before it died? Did you check you TB?
Old 07-23-2016, 01:56 PM
thanks for the tips, ill check those out
cutchemist42
06-07-2013 04:19 AM
DoubleB
VAG-COM Discussion
03-10-2009 04:48 AM
polo92gsr
03-27-2008 12:10 PM
Nogaro Stg3
06-10-2006 08:24 AM
Quick Reply: allroad 2.7t power failure while driving
