Allroad - no reverse , no neutral
Okay so a couple months back the tip d-drum broke, causing no forward drive. I ended up finding a used trans and switched over the d-drum. Everything came together okay and when I was ready to run the car no all it does is drive forward. In park car move as if in drive but the parking pawl stops the car, also in reverse and neutral car moves forward. Hooked up vag-com and did not get any trans codes, also solinoids and shifter location all seem fine. Will check shift linkage again but I figured it looked right. Going crazy here, does anyone know what this could be or any advice/help would be appreciated. I guess before I start taking everything apart again I would like to be sure 100% that its the trans. Would it help to disconnect the TCM ??
Thanks
Thanks
Thanks
Thanks
Okay disconnect power cable to trans, got under the car to make sure the linkage is right made some adjustments and started the car. Started car and it did seem like it was pulling forward, now when I moved thru the gears it seems the trans lost power. No all gears are neutral, does this mean my trans crapped out ?
Civuck
Audi A3 / S3 / RS 3 MKII
15
12-09-2016 03:06 PM
4Driver4
VAG-COM Discussion
11
05-22-2007 03:04 AM
kutscha
02-16-2004 05:08 AM
Dennis H.
09-28-2001 12:50 PM
