allroad tcm woes
i wanted to make sure this was corrosion i was seeing. quick question transman, i dropped my tranny pan and found two small pieces of metal. i did an actuator test under the tranmsision section of my scanner, i have vag 401x. it was saying open to short to all solenoids and pressure control valves. when in reverse or drive the car just revs and then if i rev to high it slams into gear. what i have been doing is removing the tcu and driving around in limp mode then when on the highwat reconnecting the tcu and then i can drive in 3,4,5 in d,s, or tip, but it just revs in gears 1,2. so my question is should i assume my tranny is toast?
Ginstervrt
13
01-08-2013 06:17 PM
PaulW
01-01-2005 06:39 PM
Kgnast-Nemo4.2
10
05-22-2004 08:18 AM
