Anyone know which front axle shields fit the 2.7 allroad tiptronic?
I have a 2004 allroad with the tiptronic transmission. My inner axle boots were torn, so I just installed new axles. I noticed that I didnt have the axle shields, but it looks like there is 3 threaded holes above the inner axle mount where a shield could go (the heat/dust shields that are directly above the inner boots on the front axles are the ones i am referring too). I wouldnt mind having the shields to help divert some of the turbo heat away from the axles, even if they dont do that much. I called audi and I was told that the allroad only ever had axle shields on the 4.2, not the 2.7. Has anyone found shields that fit these mounting holes?
I went to a local pick a part and there is a 2000 a6 quattro with the 2.8 liter, auto (not sure if tip). It has the shields on it but im not sure if they'll fit. The part numbers the dealership gave me for this cars are; Left=4b0863187c, Right=4b0863188d.... Would these fit my allroad? If not, which shields should I be hunting down? Thanks for any info anyone has for me.
There is definitely shield, Audi merchant guys are false!
Here are the numbers MY2001 -
adjust if necessary
Buy Drive shaft for Audi A6 allroad quattro 2001 RDW parts catalog in our car shop
adjust if necessary
Left side: 8D0407719
Right side: 4D0407722E
http://www.jimellisaudiparts.com/showAssembly.aspx?ukey_assembly=751607&ukey_make=1 081&ukey_model=15628&modelYear=2004&ukey_category= 21739&ukey_driveLine=8051
Rene Edwards van Muijen
05-18-2017 08:49 AM
